programming a function whose result is a function
ptc-4507537
Hi...
Can someone tell my why I can't programm a function whose result is a function? Or show me a solution?
I have attach a file with the problem.
Thank you...
Thank you for your help. the solution of Alan ist good.
Oliver
10 REPLIES 10
MikeArmstrong
(To:ptc-4507537)
No file attached.
Mike
It looks to me like you're trying to do symbolic math. While mathcad has a symbolic processor it's weak and buggy compared to some others.
That said, you can do what you want, just not in a program.
Something like the attached?
Next time please include a Mathcad file, not only a screenshot.
WE
MikeArmstrong
I believe he was meant to attached the worksheet, not just a screenshot.
Mike
Please attach your Mathcad worksheet to the message.
Thank you for your suggestions
I must constantly transform a polygon (s-Domain) in a normal form. For this I need a symbolic function that I can call always.
I think that Mathcad can' t access a vector in a defined function.
I attach my Mathcad worksheet to my message
Does the attached help any?
Alan
Edited: Slightly improved file.
I can get some of the way to understanding what MathCad is doing, but there are a number of issues that don't make sense.
1. Changing N & D to N(x) & D(x) in the std definition stops it working,
2. Calculating Z.3(0) fails but creating a function y with the substitution works ??
I must be missing something obvious...
Hopefully the attached helps but I would appreciate knowing the final outcome (if it works)
Andy
Here's a vectorised version.
Alan
Oliver
