"top 10" values of a data set- no function?
JBlackhole
16-Pearl
To all,
is there not a function in mathcad to return the "top N" value of a data set?
RichardJ
(To:JBlackhole)
You can just use sort() or csort(), followed by submatrix(0,9,0,cols()-1)
RichardJ
(To:JBlackhole)
Thanks. Thought there was a specific function like in xls (LARGE) to do the job directly
