I would like to create a program in which I choose between the 3 cases. To each case it corresponds a pair (U1, x1), (U2, x2) or (U3, x3) and only one case should be ploted as U and x pair. How can I do this using control functions?
Thank you
Here are two possible solutions using simple webcontrols (not scriptable, so there is no warning at startup)
PS: We had pretty much the same question with the very same solution here: http://communities.ptc.com/message/236154#236154
