If DPM license is not renewed, will Solution Framework entities be impacted?
SF_10006600
3-Newcomer
I have a customer who will not be renewing DPM, but needs to continue using the PTC.Base entities from the Solution Framework.  These entities were added as part of the DPM installation.  Will letting DPM expire impact the solution framework extension entities?
@SF_10006600 ,
Thank you for posting your question to the Community.
For circumstances such as this, we are recommending that you reach out to your Client Success Manager or your PTC Sales Representative.
They are better suited to answering entitlement and licensing of components questions.
As a note, Solution Framework is not part of the Out-Of-Box DPM offering, and is an unsupported Extended Add-on for DPM.
You can find the Solution Framework repo on github here: https://github.com/PTCInc/twx-solution-framework
Neel
@SF_10006600 ,
Neel
Hi @SF_10006600
It appears that there is a possible solution to your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
