does anyone know help me? I customized lines of geometry from yellow to white, but the flat view is displayed white.
I do not find a way to customize it ...
Do you use basic sheet or SheetMetal?
If you use SheetMetal you have to change the file sha_demoshop.lsp
If you use basic sheet you have to change the file sd_data.lsp because the only way is to change the persitant data.
In this file you will find a section like this:
(persistent-data
:key "BASIC-SHEET-METAL-SHOP"
:value '( :DEFAULT-MATERIAL-THICKNESS 1 :DEFAULT-BEND-PROCESS "bends"
:DEFAULT-BEND-RADIUS 1 :DEFAULT-RELIEF-TYPE "rect_relief"
:DEFAULT-RELIEF-TOOL ( :WIDTH 1 ) :DEFAULT-MITER-RELIEF-TYPE
"miter_chamfer" :DEFAULT-MITER-RELIEF-TOOL ( :PERCT_DEPTH 100 )
:DEFAULT-RELIEF-DEPTH 0 :DEFAULT-CORNER-RELIEF-TYPE
"min_perp_v_corner_relief" :DEFAULT-CORNER-RELIEF-TOOL ( :MIN_WIDTH 1 )
:DEFAULT-CORNER-GAP 0.1 :DEFAULT-CHECK-PART T :DEFAULT-KEEP-WP NIL
:MATERIALS ( ( 0.5 ) ( 1 ) ( 1.25 ) ( 1.5 ) ( 2 ) ( 3 ) ( 5 ) ) :BENDS ( ( 0.4 ) ( 0.6 ) ( 0.8 ) ( 1 ) ( 1.5 ) ( 2 ) (
2.3999999999999999 ) ) :RECT-RELIEFS ( ( 0.01 ) ( 1 ) ( 1.6000000000000001 ) ( 2 ) ( 3 ) ( 10 ) ( 20 ) )
:K-FACTOR 0.4 :SHOP-UNITS ( 1 :MM ) :DEFAULT-CORNER-LONG-LIP-OFFSET 0
:DEFAULT-CORNER-CONSTELLATION :SYMMETRIC :SHARP-BEND-RADIUS 0.4
:FLAT-DEFAULT-COLOR 16777215 :FLAT-FOLD-UP-COLOR 65535
:FLAT-FOLD-DOWN-COLOR 65535 :FLAT-TOOL-COLOR 65280 :FLAT-ERROR-COLOR
16711680 :FLAT-FOLD-UP-LINETYPE 0 :FLAT-FOLD-DOWN-LINETYPE 1
:FLAT-TEXT-SIZE 3.5 :FLAT-DEFAULT-LINEWIDTH 0 :FLAT-TOOL-LINEWIDTH 0
:FLAT-ERROR-LINEWIDTH 0 :FLAT-FOLD-UP-LINEWIDTH 0
:FLAT-FOLD-DOWN-LINEWIDTH 0 :FLAT-SHOW-LABELS T
:FLAT-SHOW-REFERENCE-POINT T :FLAT-WORKPLANE-OFFSET 0 :FLAT-PART-NAME
"sha-flat" :FLAT-TRIM-BEND-LINES T :FLAT-SINGLE-BEND-TEXT NIL
:SHOW-MERGEABLE-LINES NIL ) )
And here you can change all the available entries.
Best regards
Wolfgang
