Open Drawing From Model structure
juchida
I want to open the corresponding drawing in Annotation
when I click the viewset from the Model structure .
It is troublesome because the model and drawing cannot be loaded as a set from Windchill.
KenFarley
(To:juchida)
There is no data stored in a model file that indicates which drawing(s) it is used in. A drawing has a reference to the model(s) being used in its views, but not the other way around. This makes sense, because a model could be used in one drawing, or in many drawings. You can have more than one model in a drawing, or you might have many drawings showing the progressive stages i part goes through in being manufactured (casting, machining, final grinding, etc.)
It's the same situation with parts and assemblies. An assembly knows all the parts that it is using, but a part does not have any data indicating which assemblies it is being used in.
KenFarley
(To:juchida)
juchida
(To:KenFarley)
Thank you for your reply. I agree.
Most models and drawings are related one-to-one,
so I wondered if the "Open Related Drawings" function would be possible if Modeling + Windchill could be integrated well. ..
.bdl is easy to handle, isn't it?
