Hello to everybody,
When you switch application from Annotation to SolidDesigner the browser start to refresh the list for many time... ( 7 or 8 or more )
This cause many lost time to regenerete the list of parts/Assembly you have in your project.
On some computers this operation is very slow and we do not understand what can be the cause. We have installed the suggest graphical drivers and certificated by PTC but the problems remains....
We have change also the list using show/hidden detail but the problem is the times that the system refresh this list.... Someone has some ideas how to solve this problem?
Thnks in advance
Rego
Now I have understood where the problem is.
We have a customization for integration with PDM... when you have active it on browser it become slow... very slow...
I have delete it with this command
(oli:sd-delete-browser-view "ECSPDM") and the computer now is quicly.
Thank you very much for everything.
Which version are you using?
Creo Elements/Direct Modeling 20.0 M030 20.0.3.24,26-Jan-2018
Platform Dell Precision 5820 Tower Windows 10 64bit
Graphic Nvidia Quadro P2200 Driver 431.86
I can try to update Creo Elements with M060 i saw it on PTC Software Download. Then i will update you..
Thank you
I have updated Modeling to version: M060 ( 20.6.12, 19-Jan-2019 )
But Nothing has changed... I send you a registration of my screen where you can see what happen during the refreshing....
Hi Thomas,
do you have any idea about my problem?
I am not sure what the problem is. Mine will refresh quickly and then I can start working. I am using 20.1.4.
