I have a file that has a long tree of features. One of the early features has a sketch geometry extrude. It has a pattern of three spots. I want to undo one of the three areas and select another pattern. How is this done? Right clicking on the feature or the sketch doesn't give me any options.
What software you are speaking of? Creo+/Creo Parametric or Creo Elements Direct ?
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
If you are using Creo+/Creo Parametric, you should move your post to this community to have a better chance to get an answer.
I'm using C.P 7.0
Then move your question to:
