Config.bat problem
NoelWood
Config.bat problem
Hi all,
I'm having a problem with the configuration of Creo 2.0 Parametric. The batch file that you have to run so that Creo opens up in metric doesn't work with Windows XP.
Has anyone else had this problem? if so how did you solve it?
Many thanks.
Noel Wood
Technology Technician
Desborough College
Noel,
This was a problem in the earlier build codes of Creo 2.0. The hack who put the script together (guilty!) didn't really know what he was doing and used a function that did not work on 32bit XP computers.
I've zipped up the newer version, you can download it from here. Unzip it and replace the configure.bat file you currently have with this one. That should fix things for you.
Sorry for the inconvenience.
Adam (the hack)
Hi Adam,
Thank you for your quick response, My IT suite is all running lovely now.
Noel
