I just downloaded Creo for my college course and it is giving me a licensing error 26. it will not even open parametric or direct.
Hey Caleb - first, welcome to PTC Community! I've moved this discussion into our community, where our team will be able to help diagnose the issue.
Hi Caleb,
Could you attach a screenshot of the error message? It would help if I could see the full text.
Chris
I believe I'm getting a similar issue with a new install of the Creo student version. opening Parametric and Direct brings up the splash screen, then it closes / crashes with no error message. opening structure? gives an error message, something along the lines of "unknown licensing error 26" sorry, I didn't copy it down verbatim. I've tried installing on different drives and re-installing licenses. I'm running Windows vista 32 bit.
Thanks.
Hi Wes,
If you could email - with your issue, one of our team members will be able to jump on your computer to take a look.
Chris
Thanks Chris.
