Creo 3.0 Student Edition License says "Succes!" but also "Invalid file or format"
lreimold
Good day,
I'm trying to activate my Student Edition of Creo 3.0 with the following manual:
http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf?_ga=1.113291907.521497967.1476201064
But shortly after I click on "Install License" and login into my account, he tells me that it was succesful, but also that the license is an invalid file or has an invalid format, what makes it impossible to click on "Next".
I tried it several times, disabled all kind of firewalls, rebootet, deleted the license folder, nothing works.
Any ideas?
Lukas
15 REPLIES 15
license file is saved in C:\ProgramData\PTC\Licensing directory, by default. Did you removed PTC subdirectory in C:\ProgramData directory ?
MH
I tried to delete the _license.dat file and I also tried to delete the folder "Licensing"
you can check your license file ... maybe you will find the root of the problem in it. If you publish license file contents, then I can check it, too.
Below you can find an example of Student license for K-12 students. I hope that UNI license is similar ...
INCREMENT CREOPMA_SchoolSTD3 ptc_d 34.0 12-oct-2017 \
    uncounted 107XXXXXXXXXXXXXXB7 \
    VENDOR_STRING="VSVER=2.0 \
    LO=(0,6,7,10,17,19,32,34,48,51,61,69,73,115,127,128,135,136,137,155,188,191,283,325,326,336,347)" \
    HOSTID=PTC_HOSTID=00-11-22-33-44-55 SUPERSEDE \
    ISSUER=PTC-WEB-CREOEDUSTD3 ISSUED=12-OCT-2016 \
    NOTICE="mymail@address.xx, " SIGN2="control code \
I guess that your problem can be related to network card MAC address. Maybe installation is not able to get your network card MAC address.
I can check network card status for you, if you publish output of the following command entered in DOS prompt window.
ipconfig  /all  > ip.txt
Command output is written in ip.txt file located in user home directory.
MH
Hey,
you might be right, because my license.dat file es empty when I open it with Notepadd++.
ip.txt is in German, I hope that's no problem:
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : Lukas-PC
   Prim„res DNS-Suffix . . . . . . . :
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
   DNS-Suffixsuchliste . . . . . . . : home
Ethernet-Adapter LAN-Verbindung* 9:
   Medienstatus. . . . . . . . . . . : Medium getrennt
   Verbindungsspezifisches DNS-Suffix:
   Beschreibung. . . . . . . . . . . : Juniper Network Connect Virtual Adapter
   Physikalische Adresse . . . . . . : 00-FF-B0-BB-D7-07
   DHCP aktiviert. . . . . . . . . . : Ja
   Autokonfiguration aktiviert . . . : Ja
Ethernet-Adapter Hamachi:
   Beschreibung. . . . . . . . . . . : Hamachi Network Interface
   Physikalische Adresse . . . . . . : 7A-79-19-5B-9C-8A
   IPv6-Adresse. . . . . . . . . . . : 2620:9b::195b:9c8a(Bevorzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::8433:26f:23c1:5169%20(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 25.91.156.138(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.0.0.0
   Lease erhalten. . . . . . . . . . : Mittwoch, 12. Oktober 2016 11:37:20
   Lease l„uft ab. . . . . . . . . . : Freitag, 13. Oktober 2017 13:52:11
   Standardgateway . . . . . . . . . : 2620:9b::1900:1
                                       25.0.0.1
   DHCP-Server . . . . . . . . . . . : 25.0.0.1
   DHCPv6-IAID . . . . . . . . . . . : 427456982
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-1D-66-73-D7-40-E2-30-AB-24-73
   DNS-Server  . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS ber TCP/IP . . . . . . . : Aktiviert
Ethernet-Adapter LAN-Verbindung:
   Beschreibung. . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physikalische Adresse . . . . . . : 08-62-66-10-23-C4
Drahtlos-LAN-Adapter Drahtlosnetzwerkverbindung:
   Verbindungsspezifisches DNS-Suffix: home
   Beschreibung. . . . . . . . . . . : Atheros AR9485 Wireless Network Adapter
   Physikalische Adresse . . . . . . : 40-E2-30-AB-24-73
   IPv6-Adresse. . . . . . . . . . . : 2a02:8071:31a0:1f00:6848:650c:7add:dd6c(Bevorzugt)
   Tempor„re IPv6-Adresse. . . . . . : 2a02:8071:31a0:1f00:c1f8:b9b:23a8:627f(Bevorzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::6848:650c:7add:dd6c%11(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.0.80(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   Lease erhalten. . . . . . . . . . : Donnerstag, 13. Oktober 2016 13:52:13
   Lease l„uft ab. . . . . . . . . . : Donnerstag, 13. Oktober 2016 14:52:13
   Standardgateway . . . . . . . . . : fe80::5667:51ff:fec7:a92c%11
                                       192.168.0.1
   DHCP-Server . . . . . . . . . . . : 192.168.0.1
   DHCPv6-IAID . . . . . . . . . . . : 239133232
   DNS-Server  . . . . . . . . . . . : 2a02:8071:2000:201:78:42:43:41
                                       2a02:8070:0:201:82:212:62:41
                                       192.168.0.1
Tunneladapter isatap.home:
   Beschreibung. . . . . . . . . . . : Microsoft-ISATAP-Adapter
   Physikalische Adresse . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP aktiviert. . . . . . . . . . : Nein
Tunneladapter isatap.{03DA72CF-316B-41A4-8460-ED58AE2F77F5}:
   Beschreibung. . . . . . . . . . . : Microsoft-ISATAP-Adapter #2
Tunneladapter isatap.{D8C0516A-109B-45C4-80F4-DE4E40B1AC7A}:
   Beschreibung. . . . . . . . . . . : Microsoft-ISATAP-Adapter #3
Tunneladapter isatap.{FE01AF34-B885-483F-8969-D56803355683}:
   Beschreibung. . . . . . . . . . . : Microsoft-ISATAP-Adapter #4
Tunneladapter Teredo Tunneling Pseudo-Interface:
   Beschreibung. . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
1.] disable DHCP media sense
open Dos prompt window as Administrator
run following commands to disable DHCP media sense
netsh interface ipv4 set global dhcpmediasense=disabled
netsh interface ipv6 set global dhcpmediasense=disabled
run following commands to check results
netsh interface ipv4 show global
netsh interface ipv6 show global
>> look for Dhcp Media Sense: disabled line
2.] ipconfig output
Item no.1 ... Ethernet-Adapter LAN-Verbindung* 9: ... Juniper Network Connect Virtual Adapter
Item no.2 ... Ethernet-Adapter Hamachi: ... Hamachi Network Interface
Item no.3 ... Ethernet-Adapter LAN-Verbindung: ... Realtek PCIe GBE Family Controller
Item no.4 ... Drahtlos-LAN-Adapter Drahtlosnetzwerkverbindung: ... Atheros AR9485 Wireless Network Adapter
For me Item no.1 and Item no.2 are suspicious. Disable these network adapters and rerun ipconfig /all command.
Item no.3 is common LAN card ... you are not using it.
Item no.4 is common Wifi card ... you are using it.
3.] network card order
regedit
go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkCards folder
In NetworkCards folder you can find sub-folders for your network card.
These sub-folders define the order of network cards inside Windows.
Please expand sub-folders and publish pictures of regedit window.
MH
Might it be a problem that I'm still waiting for my Product-Key to activate Windows 7?
I do not know if missing unregistered Windows 7 can be source of the problem.
12 ... 1st network card
18 ... 2nd network card
8 .... 3rd network card
It looks like Realtek PCIe GBE Family Controller is defined as 1st network card.
Suggestion:
Disable DHCP media sense and try installation.
MH
I now have Win7 activated and DHCP disabled, still "Invalid file or format"
Lukas
disable "suspicious" Item no.1 and Item no.2 and try installation.
MH
After disabling Hamachi Network Adapter, it worked.
Thank you very much.
Cheers,
Lukas
Hi Martin Hanak,
I have the same problem as Lukas had but I don't have Hamatichi.
I tried to solve it with the tips you gave Lukas but it didn't worke.
Could you help me checking my PC setting?
   Hostname  . . . . . . . . . . . . : Uli-PC
   Knotentyp . . . . . . . . . . . . : Peer-Peer
   DNS-Suffixsuchliste . . . . . . . : #*****#
Ethernet-Adapter Bluetooth-Netzwerkverbindung 2:
   Beschreibung. . . . . . . . . . . : Bluetooth-Ger„t (PAN) #2
   Physikalische Adresse . . . . . . : #*****#
   Verbindungsspezifisches DNS-Suffix: #*****#
   Beschreibung. . . . . . . . . . . : D-Link DGE-528T-Gigabit-Ethernet-Adapter
   IPv6-Adresse. . . . . . . . . . . : #*****#(Bevorzugt)
   Lease erhalten. . . . . . . . . . : Mittwoch, 26. Oktober 2016 14:47:25
   Lease l„uft ab. . . . . . . . . . : Donnerstag, 27. Oktober 2016 14:47:25
   Verbindungslokale IPv6-Adresse  . : #*****#(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : #*****#(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : #*****#
   Lease erhalten. . . . . . . . . . : Mittwoch, 26. Oktober 2016 14:47:24
   Lease l„uft ab. . . . . . . . . . : Donnerstag, 27. Oktober 2016 14:54:03
   Standardgateway . . . . . . . . . : #*****#
   DHCP-Server . . . . . . . . . . . : #*****#
   DHCPv6-IAID . . . . . . . . . . . : #*****#
   DHCPv6-Client-DUID. . . . . . . . : #*****#
   DNS-Server  . . . . . . . . . . . : #*****#
   Prim„rer WINS-Server. . . . . . . : #*****#
Tunneladapter isatap.{#*****#}:
Tunneladapter LAN-Verbindung* 11:
Tunneladapter #*****#:
With best regards!
Uli
I do not understand the meaning of ... Knotentyp: Peer-Peer
I only met Knotentyp: Hybrid
I suggest to disable ... Ethernet-Adapter Bluetooth-Netzwerkverbindung 2
18 ... I do not understand what means Remote NDIS ....
20 ... WiFi is probably disabled
8 ... LAN card ... I suggest to change 8 to 1 and restart PC
What next ... I do not know.
MH
I have installed creo 3.0 student edition recently, on the day of installation it worked but the next day it showing a warning of "license request file failed for future" and I got a mail with "sw_license_email", I tried to install again with both the files of license files but it was shows that "invalid file or format". Please find a solution for the erorr.
how to disable
item no.1 &
2
@mmkatariya222 wrote:
how to disable
item no.1 &
2
if you want to disable network card, please ask Google ... how to disable network card in windows
