My son is using the pupils version of creo (V7.0.8.0) and we are experiencing problems using the sketcher. I use creo professionally at work but haven't yet encountered this behaviour. Whithin a sketch we are unable to edit the dimensions. Double clicking will bring the dimension to editing mode but after a second or so the editing mode will end again automatically. If you are really quick you can enter a new dimension 🙂 but that is not really a workaround. Any ideas what could cause this behaviour?
Thanks for this suggestion but using the modify option is a bit tedious. But on your suggestion, I checked my other running software and I found the cause of the problem. It was an old software called Axels Punkt which changes the comma to a dot on a german keyboard numpad. After uninstalling the software, creo runs just fine again.
I guess the problem is related to some other software installed on computer.
Try following workaround:
1.] select dimesion and use Modify command from minitoolbar
2.] edit value in dialog box
