Loop generation
wkhalid
Loop generation
Hi
I have a matrix. How to generate a loop to read only one number in this matrix every time? I have to read one number each time and make some mathmatical operations and then go to the next number.
Can you help me with this?
Best regards
Waleed
RichardJ
(To:wkhalid)
"Help", "Tutorials".
14 REPLIES 14
RichardJ
(To:wkhalid)
Your description is too vague for me to be able to give you any advice. You need to post a worksheet showing exactly what it is you wish to do.
You would be better off posting questions about Mathcad in the Mathcad forums.
Thanks for your reply, see attached photo!
RichardJ
(To:wkhalid)
Please post a worksheet with at least the matrix entered in it. Aside from saving me some typing I would then know what version of Mathcad you are using.
How can I attach a mathcad worksheet on this dialogbox?
I'm using mathcad version 14.
RichardJ
(To:wkhalid)
At the top right, click on "Use advanced editor". Then look in the lower left corner.
This is my worksheet. I'm using mathcad version 14
RichardJ
(To:wkhalid)
See the attached worksheet.
Thanks for help Richard
How did you define the stress? There are two columns in s matrix!
How did you make a relation between a(stress) and m(stress), and first column in s matrix?
Best regards
RichardJ
(To:wkhalid)
There is nothing in either the image or the worksheet you posted that indicates that the second column has any use. I implemented what you asked for, and that uses only the first column.
They are functions. I passed the first column of the s matrix to them as arguments.
What I should do if I want to the second column in the future?
RichardJ
(To:wkhalid)
That depends on what you want to use it for.
I would recommend going through the tutorials. They are quite good.
Thanks, where can I find useful tutorials?
RichardJ
(To:wkhalid)
Many thanks Richard 🙂
