Rendering problem - Lights
ptc-5494285
Hello PTC Community,
This is my first thread and i have no idea were to post, i just got lost in my rendering problem and had to ask someone to help me, i hope someone will help me here.
So i have a part, went through this rendering tutorial and i started rendering with an output of an .jpeg file. I had maximum on all options and i've set all parameters and lights and scenes as i pleased.
Now this messege showed up just when i clicked "Render window". I have no idea why, i have no idea what i've pressed...
By the way, i have the student version PTC wildfire 5.0 installed. If there is some information you need to know to help me please do tell me.
Thanks in advance, cheers!
/ Emel
Hi Emel, you might want to post this question in the Academic Support section here on PTC Community - here's the link http://communities.ptc.com/community/academic-program/support
Bettina
Thank you Bettina, i will post it right away.
Emel
