Unable to connect sample thing from Raspberry PI to ThingWorx EMS using Java SDK
Srinivas-MD
HI,
I have seen through all the discussions posted here,but seems even after setting up the SSL on tomcat i get same error.
I used both ws (http - port 8087) and wss (https - port 8443), seems in both cases i get below error, i even checked the websockets echo request, i get proper response and also disabled the firewall on my ThingWorx VM and on Raspberry PI. but no luck.
I have JDK 8 on Raspberry PI and also in my host system.
Can some one help me on this please.
Log as below:
for http URL:
01:23:55.552 [com.ptcmanaged.tempthing.Main.main()] DEBUG c.p.tempthing.BaseEdgeServer - EDGE SERVER STARTING....
01:23:55.608 [com.ptcmanaged.tempthing.Main.main()] INFO  c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000]
01:23:55.637 [com.ptcmanaged.tempthing.Main.main()] DEBUG com.ptcmanaged.tempthing.Main - Connecting to ws://192.168.29.163:8087/Thingworx/WS using key 7d3de718-dfcf-4e26-b8d5-9f97b0ba72bd
01:23:55.645 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework
01:23:55.648 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 16
01:23:55.653 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent0 - sun.nio.ch.DirectBuffer.cleaner(): available
01:23:55.654 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: available
01:23:55.654 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.theUnsafe: available
01:23:55.654 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.copyMemory: available
01:23:55.655 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Bits.unaligned: true
01:23:55.656 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows
01:23:55.657 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - Java version: 7
01:23:55.657 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false
01:23:55.657 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: available
01:23:55.658 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
01:23:55.658 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
01:23:55.658 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes.  Please check the configuration for better performance.
01:23:55.659 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\srini\AppData\Local\Temp (java.io.tmpdir)
01:23:55.659 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
01:23:55.659 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: false
01:23:55.675 [com.ptcmanaged.tempthing.Main.main()] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
01:23:55.676 [com.ptcmanaged.tempthing.Main.main()] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
01:23:55.705 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 8
01:23:55.705 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 8
01:23:55.705 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
01:23:55.706 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
01:23:55.706 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
01:23:55.707 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
01:23:55.707 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
01:23:55.708 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
01:23:55.708 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
01:23:55.708 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
01:23:55.709 [com.ptcmanaged.tempthing.Main.main()] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheCleanupInterval: 5000 ms
01:23:55.715 [com.ptcmanaged.tempthing.Main.main()] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
01:23:55.716 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
01:23:55.716 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
01:23:55.717 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
01:23:55.717 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
01:23:55.744 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0xd6edad944c18a382
01:23:55.748 [Client-EndpointMonitor-1] DEBUG i.n.channel.ChannelOutboundBuffer - -Dio.netty.threadLocalDirectBufferSize: 65536
01:23:55.749 [Client-EndpointMonitor-1] DEBUG io.netty.util.Recycler - -Dio.netty.recycler.maxCapacity.default: 262144
01:23:55.757 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
01:23:55.780 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
01:23:55.792 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket Channel is connected [is open: true]
01:23:55.795 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocketClientHandshaker13 - WebSocket version 13 client handshake key: jfcfQHPQ4tZdOfM5mbleXA==, expected response: 30NuzpOtKKYdZ9vdIIRvSIzhmQs=
01:24:05.761 [Client-EndpointMonitor-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
01:24:05.764 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://192.168.29.163:8087/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
01:24:05.766 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
For https URL:
C:\Users\srini\temperature-thing\target>java -jar temperature-thing-jar-with-dependencies.jar wss://192.168.29.163:8443/Thingworx/WS 7d3de718-dfcf-4e26-b8d5-9f97b0ba72bd simulated
03:50:46.104 [main] DEBUG c.p.tempthing.BaseEdgeServer - EDGE SERVER STARTING....
03:50:46.173 [main] INFO  c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000]
03:50:46.206 [main] DEBUG com.ptcmanaged.tempthing.Main - Connecting to wss://192.168.29.163:8443/Thingworx/WS using key 7d3de718-dfcf-4e26-b8d5-9f97b0ba72bd
03:50:46.213 [main] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework
03:50:46.215 [main] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 16
03:50:46.221 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.nio.ch.DirectBuffer.cleaner(): available
03:50:46.221 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: available
03:50:46.222 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.theUnsafe: available
03:50:46.225 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.copyMemory: available
03:50:46.225 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Bits.unaligned: true
03:50:46.226 [main] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows
03:50:46.226 [main] DEBUG i.n.util.internal.PlatformDependent - Java version: 8
03:50:46.227 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false
03:50:46.228 [main] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: available
03:50:46.232 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
03:50:46.232 [main] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
03:50:46.235 [main] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes.  Please check the configuration for better performance.
03:50:46.237 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\srini\AppData\Local\Temp (java.io.tmpdir)
03:50:46.238 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
03:50:46.238 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: false
03:50:46.252 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
03:50:46.252 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
03:50:46.499 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 8
03:50:46.499 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 8
03:50:46.501 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
03:50:46.502 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
03:50:46.505 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
03:50:46.505 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
03:50:46.506 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
03:50:46.507 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
03:50:46.507 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
03:50:46.508 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
03:50:46.508 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheCleanupInterval: 5000 ms
03:50:46.514 [main] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
03:50:46.515 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
03:50:46.515 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect...
03:50:46.518 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
03:50:46.518 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
03:50:46.528 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0x37d404df17f88253
03:50:46.532 [Client-EndpointMonitor-1] DEBUG i.n.channel.ChannelOutboundBuffer - -Dio.netty.threadLocalDirectBufferSize: 65536
03:50:46.534 [Client-EndpointMonitor-1] DEBUG io.netty.util.Recycler - -Dio.netty.recycler.maxCapacity.default: 262144
03:50:46.541 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
03:50:46.550 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.NettyClientConnectionFactory - initializing a secure websocket connection [ignore ssl errors: true]
03:50:47.181 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
03:50:47.212 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket Channel is connected [is open: true]
03:50:47.215 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocketClientHandshaker13 - WebSocket version 13 client handshake key: 0+Zt9govcpotnw1WlltKRw==, expected response: QNuChs5pK6D7vUjhCjRawVvkdTA=
03:50:47.226 [NettyClient-NIO-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - TRUST-ALL X509TrustManager.checkServerTrusted called [issuer: CN=PTC PTC, OU=PTC, O=PTC, L=Ann Arbor, ST=MI, C=US, subject: CN=PTC PTC, OU=PTC, O=PTC, L=Ann Arbor, ST=MI, C=US, authType: ECDHE_RSA]
03:50:47.226 [NettyClient-NIO-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - TRUST-ALL X509TrustManager.getAcceptedIssuers called
03:50:56.547 [Client-EndpointMonitor-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: false, is active: false]
03:50:56.549 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: wss://192.168.29.163:8443/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
03:50:56.554 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
Visit: http://www.windchillguru.com
7 REPLIES 7
Can you see your ThingWorx Composer web page when you browse to 192.168.29.163:8087/Thingworx/Composer/index.html
Unless you are using an additional connection server, whatever URL:port works for browsing to composer will work for the EMS. You will have to set the security options in config.json to match your server security
Hi Al,
I don't think i am using additional connection server and i am able to access composer as well.
i am trying out the sample weather app, i don't see any config.json in that project.
When you browse to Composer does the URL start with http;// or https:// and is there any port after the host name or IP address?
Whatever hostname/IP address and port you use to browse to Composer will be what need to be in the json.config file on the Raspberry Pi. For example, if you browse to Composer using http://192.168.29.163 then you will need to enter this in json.config:
"ws_servers":[{
"host":"192.168.29.163",
"port":80
You will also need to add this to json.config:
"ws_connection":{
"encryption":"none"
Hi Al,
the URL which i use for accessing composer are as below
http://192.168.29.163:8087/Thingworx/Composer/
or
https://192.168.29.163:8443/Thingworx/Composer/
Can you tell me the location on raspberry pi where i need to place this json.config file please.
Based on your log files you must have been changing it.
There is a step-by-step guide here:
http://developer.thingworx.com/guides/thingworx-raspberry-pi-quickstart?page=5
Start in whatever directory the EMS is installed in and thn change to microserver/etc
ankigupta
(To:Srinivas-MD)
Srinivas Dwarakanath​,
I tried accessing the url and it's not accessible. Maybe it's accessible within your vpn or instance is down.
Could you please confirm that the Ports 8443 and 8087 are open on the server where ThingWorx is Running.
It isn't very clear, but these lines in the log file:
Mean that there is no network connection to the ThingWorx server
