Hot Wired Robotics #7013 Res-Q robot "Captain Hook". We did an incredible amount of concept design using the field elements to figure out the angles for the debris dump and the hang in PTC this year.
Looks cool
"Captain Hook" is going to St. Louis. Hot Wired with Vulcan and Bomb Squad were the winning alliance at FTC West Supers. Looking forward to seeing you there.
