Dear Mr. or Mrs,
I´m a student of the Technical University of Ostrava and I´m working on my dissertation.
I made a registration at PTC at 31st of january 2016 and after that I got a confirmation about registration. I downloaded your software Creo 2.0 but I still haven´t received the licence from you. Could you help me with this problem, please?
did you follow a procedure described in http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf document ?
MH
Hi Pavel,
If you're trying to install Creo 2.0, you can use this guide: http://apps.ptc.com/schools/references/install_creo2_student_uni.pdf
A product code is included in the install instructions.
Chris
