Is there a way to get a CAD or step file for PTC Creo of a sprocket that will go in an AndyMark chassis? Or, do I have to make one? Making a sprocket seems complicated. If I can't get a file, is there a good tutorial for making a sprocket?
Model it as a disk for now and I'll do what I can to get you a comprehensive set of sprocket models.
Thanks! Okay, I'll use disks. I found a sprocket in a step file of the old AndyMark chassis. But my team is using sprockets with a different number of teeth. I like PTC Creo, it runs better than Autodesk Inventor on old slow laptops.
I found sprocket CAD files at VEX Robotics:
http://www.vexrobotics.com/25-sprockets.html
Thanks! I'm all set.
These files are perfect. Much better that the random .step files I found on the internet. Thanks FRC Team 525!
