Hello- my question is with dimensioning
When adding a model driven dimension sometimes the leader lines touch the part.
Is there a quick way to clean these up instead of dragging the drag button over?
Or is there a setting to have a certain space be the standard on the drawings?
Please advise.
Thank You,
George Dominguez
george.dominguez@roberthsaw.com
Hi!
You can try a couple things, I find that selecting my dimensions and clicking Cleanup Dimension (right-click and hold after selecting the dimensions) is a decently fast way to space things out with consistency. It doesn't apply to angular or radial dimensions, but it does make a good first pass. Certain things might still need to be adjusted like witness lines.
Cleanup Dimensions
You can control witness line offset globally with the detail option 'witness_line_offset'
Hope that helps!
Hi!
Cleanup Dimensions
Hope that helps!
thank you very much for this information. it will help tremendously.
