Unable to Access Downloadable Resources for Creo Learning
OA_13958644
Hi all,
I am currently participating in
  1. Get started with Creo Parametric Concepts
  2. Get started with the Creo Parametric Interface
  3. Get Started with Creo Parametric Modeling
  4. Get Started with Creo Parametric Assembly
and am keen to make the most of the learning materials.
I've noticed that I am currently unable to locate or download any supplementary resources that would be beneficial for practicing and reinforcing the course content (e.g., assembly parts, project templates). When I navigate through the platform, I haven't found clear access points or download links for these types of materials.
Could you please provide guidance on where I can find and download these resources? I believe they would be very helpful for my learning process and for completing any associated exercises.
1. Get Started with Creo Parametric Concepts are tutorials that are theory only. There are no exercises. These are concepts.
2. For Get Started with the Creo Parametric Interface, the Overview provides you a link from which to download the files. That link is here.
3. For Get Started with Creo Parametric Modeling and Get Started with Creo Parametric Assembly, the tutorials walk you through creation of your own models on your own system. There are no models to download. You start from scratch and create the models yourself. The start parts and start assemblies used for these playlists are the ones that are installed as part of your Creo installation. If you clear the Use default template check box you should be able to choose these out of the New File Options dialog box:
If these templates don't display in this dialog then your admin may have removed them. By default these templates are all loaded in the <Creo Parametric Loadpoint>\Common Files\templates folder:
Matt
Matt Huybrecht
