Below article is no more readable
[Knowledge Hub] Windchill PLM Data Model
https://www.ptc.com/en/support/article/CS357651
@Marco_Tosin , @TomU we've manually fixed the issue and the redirect from https://www.ptc.com/en/support/article/CS357651 is now in place.
Sorry for the inconvenience caused,
Peter.
A knowledge hub article is nothing more than a table of contents linking to other articles. I can't imagine any reason why a hub article would be completely removed. Maybe @PeterCase can help. It's hard to depend on PTC articles if we can't be confident they are going to remain accessible indefinitely.
Peter.
Thanks @PeterCase
I was looking for that article because it was in my DB of articles about query builder reports.
I needed it to help a community user.
I've updated my list as well, because I'm quicker to find references that way than to search the KB.
