Changing text size and/or colour in results window.
dilgert
Is there a way to change the text size in the results window for the legend, type of stress with load set and the analysis name at the bottom?
after using CREO 3 Simulate M050  for a project recently I would have to say that the NEW Results window is still BETA -
there are some nice new features but a lot of bugs ... some of this might be from using WIn10
some of the  many issues
1. reordering results windows doesnt always work
2. axis alterations on graphs dont stick on refresh, infact almost any alternation to the default layout doesnt stick when the windows are refreshed.
3. there are issues with rotating 3D views - some window views still rotate even after the window is no longer selected
4. you can click the high and low values of legends and edit them - good idea - but the route to have them accepted is crazy
5. custom legend color pallets dont stick
Simulate has major problems with dialog box selections not sticking on next use ... this needs serious review and fixing as it creates enormous frustration
some other frustrations ....
6. there is still no fix for getting graphs along edges or curves to work in templates
7. selecting edges for curves for graphs is still majorly deficient - cant seem to chain anything - doent follow PTC standard selection methods
8. the preselection highlite in point 7  is just plain daft -why cant it filter out edges that are unusable
9. deselecting edges is buggy
i believe PTC is short changing maintenance customers with what can only be described as sloppy programming
- does any human actually test the work flow with each relaease or is it all done in software?
- there is major interface variability between different modules even on new releases
- why are they spending money on IOT when there are rafts of issues in existing software needing fixing?
JoseCoronado
(To:BurtLand)
Hello Burt Land, I’m the product manager responsible for Creo Simulate products, I really appreciate the time you took to outline the problems in Creo Simulate. I would like to provide some comments about those issues:
[JC] We verified this in Windows 10 and Windows 7 and observed that this functionality works fine. Maybe should be something specific to a scenario, case or model, please send it to me and we can try to reproduce it.
[JC] I agree with you we should work on improve it. This functionality is derived of Creo and the mentioned behavior is as-is since implementation. We will consider this enhancement for the next releases.
[JC] We were unable to reproduce this issue and haven’t observed this during daily testing activities. If any specific scenario or case or model is available then we can try to reproduce it.
[JC] I agree with you we should work on improve it. On editing the legend value and hitting enter button the value doesn’t get updated, it gets updated only when user clicks (mouse) somewhere in the graphic area. In fact enter button action should complete the edit operation but it doesn’t.
[JC] This issue is fixed already, it will come in a later build of Creo 3, likely on M090.
[JC] I agree this is a good improvement idea. Simulate don’t support location based results being saved as templates. I would consider it when we assign priorities to potential enhancements.
[JC] For multiple selection and de-selection, the user need to hold the control key. If any specific scenario or case or model is available then we can try to reproduce it
[JC] I agree this is a good improvement idea, I would consider it when we assign priorities to potential enhancements.
[JC] For multiple selection and de-selection User need to hold the control key. If any specific scenario or case or model is available then we can try to reproduce it.
You can contact me sending me an e-mail at: -.
ehaenen
(To:JoseCoronado)
Some other frustrations:
  • Legend levels: enhancement request in place, it gets reset over and over again, please provide a way to lock legend levels.
  • The wonderful totally not stylish result coordinate system keeps on appearing in the model's origin, Please provide a way to switch this default off.
  • Why are the result windows not really windows? would be great to have an alt-print screen.
