APT file Location in Creo 2
razmosis
11-Garnet
I recently loaded Creo 2, M240 (was at M090) and I've noticed and issue with my apt files.
When I output an Operation, I can Post Process my apt files as I did before, but if I run a Material Removal Simulation (now Moduleworks, was Vericut) I have to search for those apt files because the Material Removal Simulation is looking at the Working Directory instead defaulting to the home directory where all my apts are stored.
I've scrolled though the config options, but nothing seems to describe what I am looking for.  The Post Processor seems to always look to the home directory for apt files to process.
I appreciate any help with this.
Thank You,
Matt
I guess that the problem is described in https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS236126 document. PTC will not fix it in CR2.
MH
MH
Thank you, that describes the situation exactly.  I guess I am stuck with it then.  We just got new machines and Creo 4.0 M010 is loaded on them, but Management prefers we work with Creo 2.0 for the indefinite future.  I suppose this is my fault for asking for the latest date code when M090 seemed to work just fine.
Matt
