Bonjour,
je dispose d'un CREO 2 en anglais, je souhaiterais le passer en Français.
Pouvez vous m'aider ?
Merci d'avance.
cdl
Fabrice
by default Creo is installed in English, only. If you need to install additional language (for example French), you have to click Customize button and check language box.
Creo is taking regional settings from Windows. If you are using French environment, then Creo will start in French as soon as French language is installed.
MH
MH
Hi and thank you Martin, but the problem is that next : I am stuck and can not go further.
Fabrice.
I hope you did not removed your english installation. Go to CR2_loadpoint\Creo 2.0\Parametric\bin directory, locate parametric.psf file and open it in Notepad.
Path to license is defined on line beginning with ENV=PTC_D_LICENSE_FILE-=blablabla
During new installation, put blablabla put into Source field.
MH
Thanks for your help MH. we are going forward
Sorry but this soft is a bad boy !!! I can't change the language...
FT
you have to do new installation. In red field you have to enter new installation directory (the path must be different from your existing Creo installation).
MH
