CREO 4.0 Prints Too Light
dbower-3
Making the Jump to Creo 4.0.
While plotting, the plots are coming out too light, almost like a Gray-scale.  Played with the settings, but nothing has jumped out.
Any suggestions?
Thanks!
if you want to print all drawing items in black color, then use the following pentable.
pen 1 color 0 0 0; thickness .030 cm; attention_color
pen 2 color 0 0 0; thickness .025 cm;
pen 3 color 0 0 0; thickness .016 cm;
pen 4 color 0 0 0; thickness .070 cm;
pen 5 color 0 0 0; thickness .030 cm;
pen 6 color 0 0 0; thickness .016 cm;
pen 7 color 0 0 0; thickness .005 cm;
pen 8 color 0 0 0; thickness .016 cm;
MH
Hi David,
Are you using a pen table file?  If not, see if you can access this document on how to set up the pen table file:
Suggested Technique for Creating Table.pnt files and Setting Default Pens
Amit
dbower-3
(To:AmitDeshpande)
I am pointing to the same Pen Table file that we've been using with Creo 2.0.
Does this need to be modified for Creo 4.0?
Thanks for the response.
dbower-3
(To:dbower-3)
Contents of 'Table.pnt'
pen 1 thickness .030 cm; attention_color
pen 2 thickness .025 cm;
pen 3 thickness .016 cm;
pen 4 thickness .070 cm;
pen 5 thickness .030 cm;
pen 6 thickness .016 cm;
pen 7 thickness .005 cm;
pen 8 thickness .016 cm;
!PEN 1 = WHITE ENTITIES (OBJECT LINES)
!PEN 2 = YELLOW ENTITIES (TEXT, DIMENSIONS, CROSS HATCHING, LEADERS)
!PEN 3 = GRAY ENTITIES (HIDDEN LINES)
!PEN 4 = RED ENTITIES (CAN USE FOR DRAWING BORDER IF YOU CHANGE THE ENTITY COLOR TO RED IN THE FORMAT FILE)
!PEN 5 = GREEN ENTITIES (SHEETMETAL)
!PEN 6 = CYAN ENTITIES (SECTION)
!PEN 7 = DARK GRAY ENTITIES (DIMMED)
!PEN 8 = BLUE ENTITIES (SPLINE SURFACE GRID)
MH
dbower-3
(To:MartinHanak)
Thanks Martin, that did the trick!
David
