Cabling module, save a copy and cable breaks
MT_8208729
7-Bedrock
I am using Creo Parametric Release 10.0 and Datecode10.0.4.0
We use multiple harnesses with the same connectors and pinout, only the lenght and routing of the harness assembly is different.
So we have a harness assembly with corresponding cable part template that we can copy instead of doing the pinout every time manually by hand. From connector A to connector B and the cable part from A to B with correct pinout.
However, when saving the harness assemlby as a copy and the cable part within it as a copy with a new name, the pinout from Connector A to connector B breaks. Resulting in doing the pinout every time.
Hi @MT_8208729,
Can the issue be reproduced on a generic harness assembly or is it specific to this assembly?
Amol Lungare
NEW Creo+ Topics: PTC Control Center and Creo+ Portal
