Centralizing Creo Installation
twinwood-3
Hello all,
Does anybody have any experience with a centralized installation of Creo Parametric?
We are looking at installing Creo on the server and then launching parametric.exe via a batch file on the client.
Has anybody done this? Is it possible with Creo 3.0? If so, what is the impact on the network?
Tim
BenLoosli
(To:twinwood-3)
We have done this since Wildfire days.
One install, everyone is updated at the same time.
Minimal impact on the network, very little impact for the user when loading new modules while working.
I use a batch file to put a shortcut/icon to the system loaded parametric.bat file on each desktop.
You can get more elaborate with copying files and stuff if you need to keep your users 'in-line'.
TomU
(To:twinwood-3)
We also do this.  It works very well when the users have desktop machines that don't need to run Creo offsite (laptops need a local installation).  It also helps to have a gigabit network between the server and the computers.  The network speed doesn't matter much once Creo is running but it does impact the startup time.  For us, 100Mb startup time was around 60 seconds and 1Gb startup time is around 10 seconds.
I also use a custom batch file.  It's not necessary, but brings additional flexibility.  I do things like cleanup old files, set environment variables, and create folders (if not already present).  Having my own script on the front end lets me change what build (or version) of Creo users run without ever changing the shortcut on their desktop.  I even have it setup to process command line variables.  This let's me use different shortcuts for different groups/departments but still only have one script.
I've attached the launch script and cleanup script.  Hopefully this gives you some ideas.
Edit:  Also added zip version in case you can't download bat files.
BenLoosli
(To:TomU)
I can't download either! IT has us locked down tight.
TomU
(To:BenLoosli)
Bummer.  Here are text versions of both:  (this will be long....)
launch_creo.bat
@echo off
goto done_help
:help
echo Starts Creo Parametric
echo.
echo [/License ^| /APD ^| /Engineering ^| /Toolroom ^| /AAX ^| /AdvSE ^| /EngineerII ^| /MDO]
echo [/clean] [/Debug] [/Version] [/WF5 ^| /CP3] [/DEV] [/NoCache] [/Verbose]
echo.
echo   /License          Launch the license selection menu
echo   /APD              Start Creo using settings for the APD department
echo   /Engineering      Start Creo using settings for the Engineering Department
echo   /Toolroom         Start Creo using settings for the Toolroom
echo   /AAX              Start Creo using the AAX license
echo   /AdvSE            Start Creo using the AdvSE license (Wildfire 5 only)
echo   /MDO              Start Creo using the MDO license
echo   /EngineerII       Start Creo using the ENGINEER II license
echo   /Clean            Start Creo in a clean workspace.  Personal config.pro files
echo                     will not be loaded during startup.
echo   /Debug            Start Creo with debuging enabled
echo   /Version          Launch the version selection menu
echo   /WF5              Start Wildfire 5.0 (latest version)
echo   /CP3              Start Creo Parametric 3.0 (latest version)
echo   /DEV              Use alternate workspace cache for development
echo   /NoCache          Do not set a cache location.
echo.
goto done
:done_help
color 1F
REM Set environment variables
set CLEAN=NO
set DEBUG=NO
set DEV=NO
set NOCACHE=NO
set LICENSE=
set VERSION=
set VERBOSE=
set OPTION_CLEAN=
set OPTION_DEBUG=
set CREOPMA_FEATURE_NAME=
rem Check for startup option 1
if /I "%1"=="" goto donecheck
if /I "%1"=="?" goto help
if /I "%1"=="/?" goto help
if /I "%1"=="h" goto help
if /I "%1"=="/h" goto help
if /I "%1"=="help" goto help
if /I "%1"=="/help" goto help
if /I "%1"=="license" set LICENSE=SELECT
if /I "%1"=="/license" set LICENSE=SELECT
if /I "%1"=="APD" set LICENSE=APD
if /I "%1"=="/APD" set LICENSE=APD
if /I "%1"=="Engineering" set LICENSE=ENGINEERING
if /I "%1"=="/Engineering" set LICENSE=ENGINEERING
if /I "%1"=="Toolroom" set LICENSE=TOOLROOM
if /I "%1"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%1"=="AAX" set LICENSE=AAX
if /I "%1"=="/AAX" set LICENSE=AAX
if /I "%1"=="AdvSE" set LICENSE=AdvSE
if /I "%1"=="/AdvSE" set LICENSE=AdvSE
if /I "%1"=="Flex3C" set LICENSE=Flex3C
if /I "%1"=="/Flex3C" set LICENSE=Flex3C
if /I "%1"=="MDO" set LICENSE=MDO
if /I "%1"=="/MDO" set LICENSE=MDO
if /I "%1"=="EngineerII" set LICENSE=EngineerII
if /I "%1"=="/EngineerII" set LICENSE=EngineerII
if /I "%1"=="Clean" set CLEAN=YES
if /I "%1"=="/Clean" set CLEAN=YES
if /I "%1"=="Debug" set DEBUG=YES
if /I "%1"=="/Debug" set DEBUG=YES
if /I "%1"=="Version" set VERSION=SELECT
if /I "%1"=="/Version" set VERSION=SELECT
if /I "%1"=="WF5" set VERSION=WF5
if /I "%1"=="/WF5" set VERSION=WF5
if /I "%1"=="CP3" set VERSION=CP3
if /I "%1"=="/CP3" set VERSION=CP3
if /I "%1"=="CP3F000" set VERSION=CP3F000
if /I "%1"=="/CP3F000" set VERSION=CP3F000
if /I "%1"=="CP3M010" set VERSION=CP3M010
if /I "%1"=="/CP3M010" set VERSION=CP3M010
if /I "%1"=="CP3M020" set VERSION=CP3M020
if /I "%1"=="/CP3M020" set VERSION=CP3M020
if /I "%1"=="CP3M030" set VERSION=CP3M030
if /I "%1"=="/CP3M030" set VERSION=CP3M030
if /I "%1"=="CP3M040" set VERSION=CP3M040
if /I "%1"=="/CP3M040" set VERSION=CP3M040
if /I "%1"=="CP3M050" set VERSION=CP3M050
if /I "%1"=="/CP3M050" set VERSION=CP3M050
if /I "%1"=="CP3M060" set VERSION=CP3M060
if /I "%1"=="/CP3M060" set VERSION=CP3M060
if /I "%1"=="CP3M070" set VERSION=CP3M070
if /I "%1"=="/CP3M070" set VERSION=CP3M070
if /I "%1"=="CP3M080" set VERSION=CP3M080
if /I "%1"=="/CP3M080" set VERSION=CP3M080
if /I "%1"=="DEV" set DEV=YES
if /I "%1"=="/DEV" set DEV=YES
if /I "%1"=="VERBOSE" set VERBOSE=YES
if /I "%1"=="/VERBOSE" set VERBOSE=YES
if /I "%1"=="NoCache" set NOCACHE=YES
if /I "%1"=="/NoCache" set NOCACHE=YES
rem Check for startup option 2
if /I "%2"=="" goto donecheck
if /I "%2"=="license" set LICENSE=SELECT
if /I "%2"=="/license" set LICENSE=SELECT
if /I "%2"=="APD" set LICENSE=APD
if /I "%2"=="/APD" set LICENSE=APD
if /I "%2"=="Engineering" set LICENSE=ENGINEERING
if /I "%2"=="/Engineering" set LICENSE=ENGINEERING
if /I "%2"=="Toolroom" set LICENSE=TOOLROOM
if /I "%2"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%2"=="AAX" set LICENSE=AAX
if /I "%2"=="/AAX" set LICENSE=AAX
if /I "%2"=="AdvSE" set LICENSE=AdvSE
if /I "%2"=="/AdvSE" set LICENSE=AdvSE
if /I "%2"=="Flex3C" set LICENSE=Flex3C
if /I "%2"=="/Flex3C" set LICENSE=Flex3C
if /I "%2"=="MDO" set LICENSE=MDO
if /I "%2"=="/MDO" set LICENSE=MDO
if /I "%2"=="EngineerII" set LICENSE=EngineerII
if /I "%2"=="/EngineerII" set LICENSE=EngineerII
if /I "%2"=="Clean" set CLEAN=YES
if /I "%2"=="/Clean" set CLEAN=YES
if /I "%2"=="Debug" set DEBUG=YES
if /I "%2"=="/Debug" set DEBUG=YES
if /I "%2"=="Version" set VERSION=SELECT
if /I "%2"=="/Version" set VERSION=SELECT
if /I "%2"=="WF5" set VERSION=WF5
if /I "%2"=="/WF5" set VERSION=WF5
if /I "%2"=="CP3" set VERSION=CP3
if /I "%2"=="/CP3" set VERSION=CP3
if /I "%2"=="CP3F000" set VERSION=CP3F000
if /I "%2"=="/CP3F000" set VERSION=CP3F000
if /I "%2"=="CP3M010" set VERSION=CP3M010
if /I "%2"=="/CP3M010" set VERSION=CP3M010
if /I "%2"=="CP3M020" set VERSION=CP3M020
if /I "%2"=="/CP3M020" set VERSION=CP3M020
if /I "%2"=="CP3M030" set VERSION=CP3M030
if /I "%2"=="/CP3M030" set VERSION=CP3M030
if /I "%2"=="CP3M040" set VERSION=CP3M040
if /I "%2"=="/CP3M040" set VERSION=CP3M040
if /I "%2"=="CP3M050" set VERSION=CP3M050
if /I "%2"=="/CP3M050" set VERSION=CP3M050
if /I "%2"=="CP3M060" set VERSION=CP3M060
if /I "%2"=="/CP3M060" set VERSION=CP3M060
if /I "%2"=="CP3M070" set VERSION=CP3M070
if /I "%2"=="/CP3M070" set VERSION=CP3M070
if /I "%2"=="CP3M080" set VERSION=CP3M080
if /I "%2"=="/CP3M080" set VERSION=CP3M080
if /I "%2"=="DEV" set DEV=YES
if /I "%2"=="/DEV" set DEV=YES
if /I "%2"=="VERBOSE" set VERBOSE=YES
if /I "%2"=="/VERBOSE" set VERBOSE=YES
if /I "%2"=="NoCache" set NOCACHE=YES
if /I "%2"=="/NoCache" set NOCACHE=YES
rem Check for startup option 3
if /I "%3"=="" goto donecheck
if /I "%3"=="license" set LICENSE=SELECT
if /I "%3"=="/license" set LICENSE=SELECT
if /I "%3"=="APD" set LICENSE=APD
if /I "%3"=="/APD" set LICENSE=APD
if /I "%3"=="Engineering" set LICENSE=ENGINEERING
if /I "%3"=="/Engineering" set LICENSE=ENGINEERING
if /I "%3"=="Toolroom" set LICENSE=TOOLROOM
if /I "%3"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%3"=="AAX" set LICENSE=AAX
if /I "%3"=="/AAX" set LICENSE=AAX
if /I "%3"=="AdvSE" set LICENSE=AdvSE
if /I "%3"=="/AdvSE" set LICENSE=AdvSE
if /I "%3"=="Flex3C" set LICENSE=Flex3C
if /I "%3"=="/Flex3C" set LICENSE=Flex3C
if /I "%3"=="MDO" set LICENSE=MDO
if /I "%3"=="/MDO" set LICENSE=MDO
if /I "%3"=="EngineerII" set LICENSE=EngineerII
if /I "%3"=="/EngineerII" set LICENSE=EngineerII
if /I "%3"=="Clean" set CLEAN=YES
if /I "%3"=="/Clean" set CLEAN=YES
if /I "%3"=="Debug" set DEBUG=YES
if /I "%3"=="/Debug" set DEBUG=YES
if /I "%3"=="Version" set VERSION=SELECT
if /I "%3"=="/Version" set VERSION=SELECT
if /I "%3"=="WF5" set VERSION=WF5
if /I "%3"=="/WF5" set VERSION=WF5
if /I "%3"=="CP3" set VERSION=CP3
if /I "%3"=="/CP3" set VERSION=CP3
if /I "%3"=="CP3F000" set VERSION=CP3F000
if /I "%3"=="/CP3F000" set VERSION=CP3F000
if /I "%3"=="CP3M010" set VERSION=CP3M010
if /I "%3"=="/CP3M010" set VERSION=CP3M010
if /I "%3"=="CP3M020" set VERSION=CP3M020
if /I "%3"=="/CP3M020" set VERSION=CP3M020
if /I "%3"=="CP3M030" set VERSION=CP3M030
if /I "%3"=="/CP3M030" set VERSION=CP3M030
if /I "%3"=="CP3M040" set VERSION=CP3M040
if /I "%3"=="/CP3M040" set VERSION=CP3M040
if /I "%3"=="CP3M050" set VERSION=CP3M050
if /I "%3"=="/CP3M050" set VERSION=CP3M050
if /I "%3"=="CP3M060" set VERSION=CP3M060
if /I "%3"=="/CP3M060" set VERSION=CP3M060
if /I "%3"=="CP3M070" set VERSION=CP3M070
if /I "%3"=="/CP3M070" set VERSION=CP3M070
if /I "%3"=="CP3M080" set VERSION=CP3M080
if /I "%3"=="/CP3M080" set VERSION=CP3M080
if /I "%3"=="DEV" set DEV=YES
if /I "%3"=="/DEV" set DEV=YES
if /I "%3"=="VERBOSE" set VERBOSE=YES
if /I "%3"=="/VERBOSE" set VERBOSE=YES
if /I "%3"=="NoCache" set NOCACHE=YES
if /I "%3"=="/NoCache" set NOCACHE=YES
rem Check for startup option 4
if /I "%4"=="" goto donecheck
if /I "%4"=="license" set LICENSE=SELECT
if /I "%4"=="/license" set LICENSE=SELECT
if /I "%4"=="APD" set LICENSE=APD
if /I "%4"=="/APD" set LICENSE=APD
if /I "%4"=="Engineering" set LICENSE=ENGINEERING
if /I "%4"=="/Engineering" set LICENSE=ENGINEERING
if /I "%4"=="Toolroom" set LICENSE=TOOLROOM
if /I "%4"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%4"=="AAX" set LICENSE=AAX
if /I "%4"=="/AAX" set LICENSE=AAX
if /I "%4"=="AdvSE" set LICENSE=AdvSE
if /I "%4"=="/AdvSE" set LICENSE=AdvSE
if /I "%4"=="Flex3C" set LICENSE=Flex3C
if /I "%4"=="/Flex3C" set LICENSE=Flex3C
if /I "%4"=="MDO" set LICENSE=MDO
if /I "%4"=="/MDO" set LICENSE=MDO
if /I "%4"=="EngineerII" set LICENSE=EngineerII
if /I "%4"=="/EngineerII" set LICENSE=EngineerII
if /I "%4"=="Clean" set CLEAN=YES
if /I "%4"=="/Clean" set CLEAN=YES
if /I "%4"=="Debug" set DEBUG=YES
if /I "%4"=="/Debug" set DEBUG=YES
if /I "%4"=="Version" set VERSION=SELECT
if /I "%4"=="/Version" set VERSION=SELECT
if /I "%4"=="WF5" set VERSION=WF5
if /I "%4"=="/WF5" set VERSION=WF5
if /I "%4"=="CP3" set VERSION=CP3
if /I "%4"=="/CP3" set VERSION=CP3
if /I "%4"=="CP3F000" set VERSION=CP3F000
if /I "%4"=="/CP3F000" set VERSION=CP3F000
if /I "%4"=="CP3M010" set VERSION=CP3M010
if /I "%4"=="/CP3M010" set VERSION=CP3M010
if /I "%4"=="CP3M020" set VERSION=CP3M020
if /I "%4"=="/CP3M020" set VERSION=CP3M020
if /I "%4"=="CP3M030" set VERSION=CP3M030
if /I "%4"=="/CP3M030" set VERSION=CP3M030
if /I "%4"=="CP3M040" set VERSION=CP3M040
if /I "%4"=="/CP3M040" set VERSION=CP3M040
if /I "%4"=="CP3M050" set VERSION=CP3M050
if /I "%4"=="/CP3M050" set VERSION=CP3M050
if /I "%4"=="CP3M060" set VERSION=CP3M060
if /I "%4"=="/CP3M060" set VERSION=CP3M060
if /I "%4"=="CP3M070" set VERSION=CP3M070
if /I "%4"=="/CP3M070" set VERSION=CP3M070
if /I "%4"=="CP3M080" set VERSION=CP3M080
if /I "%4"=="/CP3M080" set VERSION=CP3M080
if /I "%4"=="DEV" set DEV=YES
if /I "%4"=="/DEV" set DEV=YES
if /I "%4"=="VERBOSE" set VERBOSE=YES
if /I "%4"=="/VERBOSE" set VERBOSE=YES
if /I "%4"=="NoCache" set NOCACHE=YES
if /I "%4"=="/NoCache" set NOCACHE=YES
rem Check for startup option 5
if /I "%5"=="" goto donecheck
if /I "%5"=="license" set LICENSE=SELECT
if /I "%5"=="/license" set LICENSE=SELECT
if /I "%5"=="APD" set LICENSE=APD
if /I "%5"=="/APD" set LICENSE=APD
if /I "%5"=="Engineering" set LICENSE=ENGINEERING
if /I "%5"=="/Engineering" set LICENSE=ENGINEERING
if /I "%5"=="Toolroom" set LICENSE=TOOLROOM
if /I "%5"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%5"=="AAX" set LICENSE=AAX
if /I "%5"=="/AAX" set LICENSE=AAX
if /I "%5"=="AdvSE" set LICENSE=AdvSE
if /I "%5"=="/AdvSE" set LICENSE=AdvSE
if /I "%5"=="Flex3C" set LICENSE=Flex3C
if /I "%5"=="/Flex3C" set LICENSE=Flex3C
if /I "%5"=="MDO" set LICENSE=MDO
if /I "%5"=="/MDO" set LICENSE=MDO
if /I "%5"=="EngineerII" set LICENSE=EngineerII
if /I "%5"=="/EngineerII" set LICENSE=EngineerII
if /I "%5"=="Clean" set CLEAN=YES
if /I "%5"=="/Clean" set CLEAN=YES
if /I "%5"=="Debug" set DEBUG=YES
if /I "%5"=="/Debug" set DEBUG=YES
if /I "%5"=="Version" set VERSION=SELECT
if /I "%5"=="/Version" set VERSION=SELECT
if /I "%5"=="WF5" set VERSION=WF5
if /I "%5"=="/WF5" set VERSION=WF5
if /I "%5"=="CP3" set VERSION=CP3
if /I "%5"=="/CP3" set VERSION=CP3
if /I "%5"=="CP3F000" set VERSION=CP3F000
if /I "%5"=="/CP3F000" set VERSION=CP3F000
if /I "%5"=="CP3M010" set VERSION=CP3M010
if /I "%5"=="/CP3M010" set VERSION=CP3M010
if /I "%5"=="CP3M020" set VERSION=CP3M020
if /I "%5"=="/CP3M020" set VERSION=CP3M020
if /I "%5"=="CP3M030" set VERSION=CP3M030
if /I "%5"=="/CP3M030" set VERSION=CP3M030
if /I "%5"=="CP3M040" set VERSION=CP3M040
if /I "%5"=="/CP3M040" set VERSION=CP3M040
if /I "%5"=="CP3M050" set VERSION=CP3M050
if /I "%5"=="/CP3M050" set VERSION=CP3M050
if /I "%5"=="CP3M060" set VERSION=CP3M060
if /I "%5"=="/CP3M060" set VERSION=CP3M060
if /I "%5"=="CP3M070" set VERSION=CP3M070
if /I "%5"=="/CP3M070" set VERSION=CP3M070
if /I "%5"=="CP3M080" set VERSION=CP3M080
if /I "%5"=="/CP3M080" set VERSION=CP3M080
if /I "%5"=="DEV" set DEV=YES
if /I "%5"=="/DEV" set DEV=YES
if /I "%5"=="VERBOSE" set VERBOSE=YES
if /I "%5"=="/VERBOSE" set VERBOSE=YES
if /I "%5"=="NoCache" set NOCACHE=YES
if /I "%5"=="/NoCache" set NOCACHE=YES
rem Check for startup option 6
if /I "%6"=="" goto donecheck
if /I "%6"=="license" set LICENSE=SELECT
if /I "%6"=="/license" set LICENSE=SELECT
if /I "%6"=="APD" set LICENSE=APD
if /I "%6"=="/APD" set LICENSE=APD
if /I "%6"=="Engineering" set LICENSE=ENGINEERING
if /I "%6"=="/Engineering" set LICENSE=ENGINEERING
if /I "%6"=="Toolroom" set LICENSE=TOOLROOM
if /I "%6"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%6"=="AAX" set LICENSE=AAX
if /I "%6"=="/AAX" set LICENSE=AAX
if /I "%6"=="AdvSE" set LICENSE=AdvSE
if /I "%6"=="/AdvSE" set LICENSE=AdvSE
if /I "%6"=="Flex3C" set LICENSE=Flex3C
if /I "%6"=="/Flex3C" set LICENSE=Flex3C
if /I "%6"=="MDO" set LICENSE=MDO
if /I "%6"=="/MDO" set LICENSE=MDO
if /I "%6"=="EngineerII" set LICENSE=EngineerII
if /I "%6"=="/EngineerII" set LICENSE=EngineerII
if /I "%6"=="Clean" set CLEAN=YES
if /I "%6"=="/Clean" set CLEAN=YES
if /I "%6"=="Debug" set DEBUG=YES
if /I "%6"=="/Debug" set DEBUG=YES
if /I "%6"=="Version" set VERSION=SELECT
if /I "%6"=="/Version" set VERSION=SELECT
if /I "%6"=="WF5" set VERSION=WF5
if /I "%6"=="/WF5" set VERSION=WF5
if /I "%6"=="CP3" set VERSION=CP3
if /I "%6"=="/CP3" set VERSION=CP3
if /I "%6"=="CP3F000" set VERSION=CP3F000
if /I "%6"=="/CP3F000" set VERSION=CP3F000
if /I "%6"=="CP3M010" set VERSION=CP3M010
if /I "%6"=="/CP3M010" set VERSION=CP3M010
if /I "%6"=="CP3M020" set VERSION=CP3M020
if /I "%6"=="/CP3M020" set VERSION=CP3M020
if /I "%6"=="CP3M030" set VERSION=CP3M030
if /I "%6"=="/CP3M030" set VERSION=CP3M030
if /I "%6"=="CP3M040" set VERSION=CP3M040
if /I "%6"=="/CP3M040" set VERSION=CP3M040
if /I "%6"=="CP3M050" set VERSION=CP3M050
if /I "%6"=="/CP3M050" set VERSION=CP3M050
if /I "%6"=="CP3M060" set VERSION=CP3M060
if /I "%6"=="/CP3M060" set VERSION=CP3M060
if /I "%6"=="CP3M070" set VERSION=CP3M070
if /I "%6"=="/CP3M070" set VERSION=CP3M070
if /I "%6"=="CP3M080" set VERSION=CP3M080
if /I "%6"=="/CP3M080" set VERSION=CP3M080
if /I "%6"=="DEV" set DEV=YES
if /I "%6"=="/DEV" set DEV=YES
if /I "%6"=="VERBOSE" set VERBOSE=YES
if /I "%6"=="/VERBOSE" set VERBOSE=YES
if /I "%6"=="NoCache" set NOCACHE=YES
if /I "%6"=="/NoCache" set NOCACHE=YES
rem Check for startup option 7
if /I "%7"=="" goto donecheck
if /I "%7"=="license" set LICENSE=SELECT
if /I "%7"=="/license" set LICENSE=SELECT
if /I "%7"=="APD" set LICENSE=APD
if /I "%7"=="/APD" set LICENSE=APD
if /I "%7"=="Engineering" set LICENSE=ENGINEERING
if /I "%7"=="/Engineering" set LICENSE=ENGINEERING
if /I "%7"=="Toolroom" set LICENSE=TOOLROOM
if /I "%7"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%7"=="AAX" set LICENSE=AAX
if /I "%7"=="/AAX" set LICENSE=AAX
if /I "%7"=="AdvSE" set LICENSE=AdvSE
if /I "%7"=="/AdvSE" set LICENSE=AdvSE
if /I "%7"=="Flex3C" set LICENSE=Flex3C
if /I "%7"=="/Flex3C" set LICENSE=Flex3C
if /I "%7"=="MDO" set LICENSE=MDO
if /I "%7"=="/MDO" set LICENSE=MDO
if /I "%7"=="EngineerII" set LICENSE=EngineerII
if /I "%7"=="/EngineerII" set LICENSE=EngineerII
if /I "%7"=="Clean" set CLEAN=YES
if /I "%7"=="/Clean" set CLEAN=YES
if /I "%7"=="Debug" set DEBUG=YES
if /I "%7"=="/Debug" set DEBUG=YES
if /I "%7"=="Version" set VERSION=SELECT
if /I "%7"=="/Version" set VERSION=SELECT
if /I "%7"=="WF5" set VERSION=WF5
if /I "%7"=="/WF5" set VERSION=WF5
if /I "%7"=="CP3" set VERSION=CP3
if /I "%7"=="/CP3" set VERSION=CP3
if /I "%7"=="CP3F000" set VERSION=CP3F000
if /I "%7"=="/CP3F000" set VERSION=CP3F000
if /I "%7"=="CP3M010" set VERSION=CP3M010
if /I "%7"=="/CP3M010" set VERSION=CP3M010
if /I "%7"=="CP3M020" set VERSION=CP3M020
if /I "%7"=="/CP3M020" set VERSION=CP3M020
if /I "%7"=="CP3M030" set VERSION=CP3M030
if /I "%7"=="/CP3M030" set VERSION=CP3M030
if /I "%7"=="CP3M040" set VERSION=CP3M040
if /I "%7"=="/CP3M040" set VERSION=CP3M040
if /I "%7"=="CP3M050" set VERSION=CP3M050
if /I "%7"=="/CP3M050" set VERSION=CP3M050
if /I "%7"=="CP3M060" set VERSION=CP3M060
if /I "%7"=="/CP3M060" set VERSION=CP3M060
if /I "%7"=="CP3M070" set VERSION=CP3M070
if /I "%7"=="/CP3M070" set VERSION=CP3M070
if /I "%7"=="CP3M080" set VERSION=CP3M080
if /I "%7"=="/CP3M080" set VERSION=CP3M080
if /I "%7"=="DEV" set DEV=YES
if /I "%7"=="/DEV" set DEV=YES
if /I "%7"=="VERBOSE" set VERBOSE=YES
if /I "%7"=="/VERBOSE" set VERBOSE=YES
if /I "%7"=="NoCache" set NOCACHE=YES
if /I "%7"=="/NoCache" set NOCACHE=YES
rem Check for startup option 8
if /I "%8"=="" goto donecheck
if /I "%8"=="license" set LICENSE=SELECT
if /I "%8"=="/license" set LICENSE=SELECT
if /I "%8"=="APD" set LICENSE=APD
if /I "%8"=="/APD" set LICENSE=APD
if /I "%8"=="Engineering" set LICENSE=ENGINEERING
if /I "%8"=="/Engineering" set LICENSE=ENGINEERING
if /I "%8"=="Toolroom" set LICENSE=TOOLROOM
if /I "%8"=="/Toolroom" set LICENSE=TOOLROOM
if /I "%8"=="AAX" set LICENSE=AAX
if /I "%8"=="/AAX" set LICENSE=AAX
if /I "%8"=="AdvSE" set LICENSE=AdvSE
if /I "%8"=="/AdvSE" set LICENSE=AdvSE
if /I "%8"=="Flex3C" set LICENSE=Flex3C
if /I "%8"=="/Flex3C" set LICENSE=Flex3C
if /I "%8"=="MDO" set LICENSE=MDO
if /I "%8"=="/MDO" set LICENSE=MDO
if /I "%8"=="EngineerII" set LICENSE=EngineerII
if /I "%8"=="/EngineerII" set LICENSE=EngineerII
if /I "%8"=="Clean" set CLEAN=YES
if /I "%8"=="/Clean" set CLEAN=YES
if /I "%8"=="Debug" set DEBUG=YES
if /I "%8"=="/Debug" set DEBUG=YES
if /I "%8"=="Version" set VERSION=SELECT
if /I "%8"=="/Version" set VERSION=SELECT
if /I "%8"=="WF5" set VERSION=WF5
if /I "%8"=="/WF5" set VERSION=WF5
if /I "%8"=="CP3" set VERSION=CP3
if /I "%8"=="/CP3" set VERSION=CP3
if /I "%8"=="CP3F000" set VERSION=CP3F000
if /I "%8"=="/CP3F000" set VERSION=CP3F000
if /I "%8"=="CP3M010" set VERSION=CP3M010
if /I "%8"=="/CP3M010" set VERSION=CP3M010
if /I "%8"=="CP3M020" set VERSION=CP3M020
if /I "%8"=="/CP3M020" set VERSION=CP3M020
if /I "%8"=="CP3M030" set VERSION=CP3M030
if /I "%8"=="/CP3M030" set VERSION=CP3M030
if /I "%8"=="CP3M040" set VERSION=CP3M040
if /I "%8"=="/CP3M040" set VERSION=CP3M040
if /I "%8"=="CP3M050" set VERSION=CP3M050
if /I "%8"=="/CP3M050" set VERSION=CP3M050
if /I "%8"=="CP3M060" set VERSION=CP3M060
if /I "%8"=="/CP3M060" set VERSION=CP3M060
if /I "%8"=="CP3M070" set VERSION=CP3M070
if /I "%8"=="/CP3M070" set VERSION=CP3M070
if /I "%8"=="CP3M080" set VERSION=CP3M080
if /I "%8"=="/CP3M080" set VERSION=CP3M080
if /I "%8"=="DEV" set DEV=YES
if /I "%8"=="/DEV" set DEV=YES
if /I "%8"=="VERBOSE" set VERBOSE=YES
if /I "%8"=="/VERBOSE" set VERBOSE=YES
if /I "%8"=="NoCache" set NOCACHE=YES
if /I "%8"=="/NoCache" set NOCACHE=YES
:donecheck
if "%LICENSE%"=="SELECT" goto license_menu
if "%VERSION%"=="SELECT" goto version_menu
if NOT "%LICENSE%"=="" goto configure_environment
if NOT "%VERSION%"=="" goto configure_environment
:main_menu
mode con:cols=26 lines=19
color 1F
set dept=
cls
echo.
echo   ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
echo   º                    º
echo   º Select Department  º
echo   º                    º
echo   ÌÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ͹
echo   º                    º
echo   º  1. APD            º
echo   º                    º
echo   º  2. Engineering    º
echo   º                    º
echo   º  3. Tool Room      º
echo   º                    º
echo   º  4. Options        º
echo   º                    º
echo   ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
echo.
set /p dept=Select Department:
IF "%dept%"=="1" (
set LICENSE=APD
IF "%dept%"=="2" (
IF "%dept%"=="3" (
IF "%dept%"=="4" goto options_menu
goto main_menu
:options_menu
mode con:cols=26 lines=21
color 1F
set option=
cls
echo.
echo   º                    º
echo   º  Startup Options   º
echo   º                    º
echo   º                    º
echo   º  1.  Clean    [%OPTION_CLEAN%]  º
echo   º                    º
echo   º  2.  Debug    [%OPTION_DEBUG%]  º
echo   º                    º
echo   º  3. Choose License º
echo   º                    º
echo   º  4. Choose Version º
echo   º                    º
echo   º  5. Exit Options   º
echo   º                    º
echo.
set /p option=Select Department:
IF "%option%"=="1" (
IF "%CLEAN%"=="NO" (
  set CLEAN=YES
  set OPTION_CLEAN=X
IF "%CLEAN%"=="YES" (
  set CLEAN=NO
  set OPTION_CLEAN=
IF "%option%"=="2" (
IF "%DEBUG%"=="NO" (
  set DEBUG=YES
  set OPTION_DEBUG=X
IF "%DEBUG%"=="YES" (
  set DEBUG=NO
  set OPTION_DEBUG=
IF "%option%"=="3" goto license_menu
IF "%option%"=="4" goto version_menu
IF "%option%"=="5" goto main_menu
goto options_menu
:license_menu
color 1F
set lic=
cls
echo.
echo   º                    º
echo   º   Select License   º
echo   º                    º
echo   º                    º
echo   º  1. AAX            º
echo   º                    º
echo   º  2. AdvSE          º
echo   º                    º
echo   º  3. EngineerII     º
echo   º                    º
echo   º  4. MDO            º
echo   º                    º
echo   º  5. MAIN MENU      º
echo   º                    º
echo.
set /p lic=Select License:
IF "%lic%"=="1" (
set LICENSE=AAX
IF "%lic%"=="2" (
set LICENSE=AdvSE
IF "%lic%"=="3" (
IF "%lic%"=="4" (
set LICENSE=MDO
IF "%lic%"=="5" goto main_menu
goto license_menu
:version_menu
color 1F
set lic=
cls
echo.
echo   º                    º
echo   º   Select Version   º
echo   º                    º
echo   º                    º
echo   º  1. Creo 3.0 M080  º
echo   º                    º
echo   º  2. Creo 3.0 M070  º
echo   º                    º
echo   º  3. Creo 3.0 M060  º
echo   º                    º
echo   º  4. Wildfire 5.0   º
echo   º                    º
echo   º                    º
echo.
set /p ver=Select License:
IF "%ver%"=="1" (
set VERSION=CP3M080
IF "%ver%"=="2" (
set VERSION=CP3M070
IF "%ver%"=="3" (
set VERSION=CP3M060
IF "%ver%"=="4" (
set VERSION=WF5
IF "%ver%"=="5" goto main_menu
goto version_menu
:configure_environment
set PTC_HOSTNAME=%COMPUTERNAME%
REM Set Start In Directory
set WORKING_DIR=C:\ptc\workspaces
if "%CLEAN%"=="YES" (
SET HOMEDRIVE=
SET HOMEPATH=
SET HOMESHARE=
set WORKING_DIR=C:\ptc\workspaces\clean
if NOT EXIST %WORKING_DIR% md %WORKING_DIR%
c:
cd %WORKING_DIR%
REM Create trail directory
if NOT EXIST C:\ptc\trail md C:\ptc\trail
REM Configure Debugging
if "%DEBUG%"=="YES" (
set PTC_LOG_ACTIVATE=t
set PTC_LOG_DIR=%WORKING_DIR%\logs
set PTC_LOG_CONFIG=%WORKING_DIR%\logging.cfg.debug
set BSC_LOG_ACTIVATE=t
set BSC_LOG_FILE_NAME=bsc.log
set UWGM_PRINT_XML_FILES=yes
REM set UWGM_LOG_ACTIONS=true
REM set UWGM_LOG_TASK_QUEUES=true
REM set UWGM_LOG_DOWNLOAD=true
REM set UWGM_PERSIST_LOG_DEBUG=no
REM set UWGM_LOG_MEMUSE=true
copy /Y H:\ProEngineer\Bin\logging.cfg.debug %WORKING_DIR%
REM Set default version
if "%VERSION%"=="" set VERSION=CP3
if "%VERBOSE%"=="YES" (
mode con:cols=80 lines=13
echo ==== Debug Section 1 ====
echo Clean:       %CLEAN%
echo Debug:       %DEBUG%
echo DEV:         %DEV%
echo NoCache:     %NOCACHE%
echo LICENSE:     %LICENSE%
echo VERSION:     %VERSION%
echo.
pause
REM Vesion specific settings
if "%VERSION%"=="CP3F000" goto CP3F000
if "%VERSION%"=="CP3M010" goto CP3M010
if "%VERSION%"=="CP3M020" goto CP3M020
if "%VERSION%"=="CP3M030" goto CP3M030
if "%VERSION%"=="CP3M040" goto CP3M040
if "%VERSION%"=="CP3M050" goto CP3M050
if "%VERSION%"=="CP3M060" goto CP3M060
if "%VERSION%"=="CP3M070" goto CP3M070
if "%VERSION%"=="CP3M080" goto CP3M080
if "%VERSION%"=="WF5" goto WF5
if "%VERSION%"=="CP3" goto CP3M080
cls
color 1F
echo Error!
echo Version not available.
echo.
echo.
pause
goto main_menu
:WF5
set CREO_NAME=Wildfire 5 M250
set CREO_PATH=H:\ProEngineer\WF5_M250_x64
set CREO_EXE=proe.exe
if NOT "%NOCACHE%"=="YES" (
set PTC_WF_ROOT=C:\ptc\%USERNAME%\WC10_WF_Client
if "%DEV%"=="YES" set PTC_WF_ROOT=C:\ptc\%USERNAME%\WC10_WF_DEV
set resolve_comp_w_sep_process=no
goto wf5_license
:CP3F000
set CREO_NAME=Creo 3.0 F000
set CREO_PATH=H:\Creo 3.0\F000\Parametric
set CREO_EXE=parametric.exe
set PTC_WF_ROOT=C:\ptc\%USERNAME%\WC10_CP3_WGM
if "%DEV%"=="YES" set PTC_WF_ROOT=C:\ptc\%USERNAME%\WC10_CP3_DEV
goto cp3_license
:CP3M010
set CREO_NAME=Creo 3.0 M010
set CREO_PATH=H:\Creo 3.0\M010\Parametric
goto cp3_license
:CP3M020
set CREO_NAME=Creo 3.0 M020
set CREO_PATH=H:\Creo 3.0\M020\Parametric
goto cp3_license
:CP3M030
set CREO_NAME=Creo 3.0 M030
set CREO_PATH=H:\Creo 3.0\M030\Parametric
reg add "HKLM\Software\Wow6432Node\PTC\PTC Creo Parametric\3.0\2014500" /v QualityAgentOptIn /t REG_SZ /d 1 /f >NUL 2>&1
goto cp3_license
:CP3M040
set CREO_NAME=Creo 3.0 M040
set CREO_PATH=H:\Creo 3.0\M040\Parametric
reg add "HKLM\Software\Wow6432Node\PTC\PTC Creo Parametric\3.0\2015080" /v QualityAgentOptIn /t REG_SZ /d 1 /f >NUL 2>&1
goto cp3_license
:CP3M050
set CREO_NAME=Creo 3.0 M050
set CREO_PATH=H:\Creo 3.0\M050\Parametric
reg add "HKLM\Software\Wow6432Node\PTC\PTC Creo Parametric\3.0\2015200" /v QualityAgentOptIn /t REG_SZ /d 1 /f >NUL 2>&1
goto cp3_license
:CP3M060
set CREO_NAME=Creo 3.0 M060
set CREO_PATH=H:\Creo 3.0\M060\Parametric
reg add "HKLM\Software\Wow6432Node\PTC\PTC Creo Parametric\3.0\2015290" /v QualityAgentOptIn /t REG_SZ /d 1 /f >NUL 2>&1
goto cp3_license
:CP3M070
set CREO_NAME=Creo 3.0 M070
set CREO_PATH=H:\Creo 3.0\M070\Parametric
reg add "HKLM\Software\Wow6432Node\PTC\PTC Creo Parametric\3.0\2015380" /v QualityAgentOptIn /t REG_SZ /d 1 /f >NUL 2>&1
goto cp3_license
:CP3M080
set CREO_NAME=Creo 3.0 M080
set CREO_PATH=H:\Creo 3.0\M080\Parametric
reg add "HKLM\Software\Wow6432Node\PTC\PTC Creo Parametric\3.0\2015480" /v QualityAgentOptIn /t REG_SZ /d 1 /f >NUL 2>&1
goto cp3_license
:wf5_license
if "%LICENSE%"=="APD" set PROE_FEATURE_NAME=PROE_AdvSE PROE_FAPAAX PROE_FAPMDO PROE_EngineerIIAAX PROE_Flex3C ()
if "%LICENSE%"=="ENGINEERING" set PROE_FEATURE_NAME=PROE_FAPAAX PROE_EngineerIIAAX PROE_AdvSE PROE_FAPMDO PROE_Flex3C ()
if "%LICENSE%"=="TOOLROOM" set PROE_FEATURE_NAME=PROE_AdvSE PROE_FAPAAX PROE_FAPMDO PROE_EngineerIIAAX PROE_Flex3C ()
if "%LICENSE%"=="AAX" set PROE_FEATURE_NAME=PROE_FAPAAX ()
if "%LICENSE%"=="AdvSE" set PROE_FEATURE_NAME=PROE_AdvSE ()
if "%LICENSE%"=="Flex3C" set PROE_FEATURE_NAME=PROE_Flex3C ()
if "%LICENSE%"=="EngineerII" set PROE_FEATURE_NAME=PROE_EngineerIIAAX ()
if "%LICENSE%"=="MDO" set PROE_FEATURE_NAME=PROE_FAPMDO ()
if "%PROE_FEATURE_NAME%"=="" goto main_menu
goto launch
:cp3_license
if "%LICENSE%"=="APD" set CREOPMA_FEATURE_NAME=PROE_AdvSE PROE_FAPAAX PROE_EngineerIIAAX PROE_FAPMDO ()
if "%LICENSE%"=="ENGINEERING" set CREOPMA_FEATURE_NAME=PROE_FAPAAX PROE_EngineerIIAAX PROE_AdvSE PROE_FAPMDO ()
if "%LICENSE%"=="TOOLROOM" set CREOPMA_FEATURE_NAME=PROE_AdvSE PROE_FAPAAX PROE_EngineerIIAAX PROE_FAPMDO ()
if "%LICENSE%"=="AAX" set CREOPMA_FEATURE_NAME=PROE_FAPAAX ()
if "%LICENSE%"=="AdvSE" set CREOPMA_FEATURE_NAME=PROE_AdvSE ()
if "%LICENSE%"=="Flex3C" set CREOPMA_FEATURE_NAME=PROE_FAPAAX PROE_AdvSE PROE_FAPMDO ()
if "%LICENSE%"=="EngineerII" set CREOPMA_FEATURE_NAME=PROE_EngineerIIAAX ()
if "%LICENSE%"=="MDO" set CREOPMA_FEATURE_NAME=PROE_FAPMDO ()
if "%CREOPMA_FEATURE_NAME%"=="" goto main_menu
goto launch
:launch
set PRODIR=%CREO_PATH%
SET PATH=%PATH%;%CREO_PATH%\bin
mode con:cols=80 lines=15
echo ==== Debug Section 2 ====
echo Clean:       %CLEAN%
echo Debug:       %DEBUG%
echo DEV:         %DEV%
echo CREO_NAME:   %CREO_NAME%
echo CREO_EXE:    %CREO_EXE%
echo CREO_PATH:   "%CREO_PATH%"
echo FEATURE:     "%CREOPMA_FEATURE_NAME%%PROE_FEATURE_NAME%"
echo PTC_WF_ROOT: "%PTC_WF_ROOT%"
echo.
pause
mode con:cols=30 lines=4
cls
echo.
echo Cleaning up ...
echo.
if NOT "%DEBUG%"=="YES" (
start /min H:\ProEngineer\Bin\cleanup.bat %creo_path%
cls
echo.
echo Starting %CREO_NAME% ...
echo.
start "" "%CREO_PATH%\bin\%CREO_EXE%" "%CREO_PATH%\bin\parametric.psf"
timeout /t 15 /nobreak > NUL
:done
cleanup.bat
@echo off
rem mode con:cols=20 lines=1
IF NOT "%CREO_PATH%"=="" set PURGE_EXE="%CREO_PATH%\bin\purge.bat"
set WORKING_DIR=c:\ptc\workspaces
set WORKING_DRV=%WORKING_DIR:~0,2%
%WORKING_DRV%
:trail
if not exist %WORKING_DIR%\..\trail goto wspace
cd %WORKING_DIR%\..\trail
del /f /q  trail.txt.*
:wspace
if not exist %WORKING_DIR% goto end
cd %WORKING_DIR%
del /f /q *.als
del /f /q *.bde
del /f /q *.bdi
del /f /q *.bdm
del /f /q *.crc*
del /f /q *.crc.*
del /f /q *.dat*
del /f /q *.dat.*
del /f /q *.err*
del /f /q *.err.*
del /f /q *.ers*
del /f /q *.ers.*
del /f /q *.ger*
del /f /q *.ger.*
del /f /q *.inf*
del /f /q *.inf.*
del /f /q *.lge
del /f /q *.lgi
del /f /q *.log
del /f /q *.log.*
del /f /q *_log.xml
del /f /q *.m_p
del /f /q *.m_p.*
del /f /q *.memb
del /f /q *.memb.*
del /f /q *.osv
del /f /q *.osv.*
del /f /q *.pls
del /f /q *.plt
del /f /q *.prn
del /f /q *.ptd
del /f /q *.tst
del /f /q *.tst.*
del /f /q *.xch
del /f /q *.xch.*
del /f /q errors.lst.*
del /f /q iges_stats.dat*
del /f /q debug_feat_recognition.txt*
del /f /q missref.lst
del /f /q msgerror.txt
del /f /q pen_table.txt
del /f /q s2d0*.sec*
REM del /f /q *.dwg
REM del /f /q *.dxf
REM del /f /q *.igs
REM del /f /q *.jpg
REM del /f /q *.pdf
REM del /f /q *.stp
REM del /f /q current_session.pro
REM del /f /q config.win
REM del /f /q config.win.*
call %purge_exe%
:end
cls
exit
BenLoosli
(To:TomU)
Thank you
Cut and Paste works wonders!
If you want to get really fancy, you can use Windows Offline Files functionality on the client machine, to then cache the network install of creo locally to a laptop drive, borrow a license to the laptop and then work offline without having to do local installs. Also, when the network loadpoint is updated, next time the laptop connects to the network, the laptop cache will get updated
