Creo 1 Working Directory
LouGeier
We have just upgraded from Creo/Elements Pro to Creo 1 Parametric. When trying to set the default working directory, Creo seems to always try to open files from my documents by default. I have the startup location set for the correct folder, but when you launch Creo and hit open, it brings the explorer window to my documents. Is there a config.pro option or something that could be overriding the startup location?
Any help would be appreciated.
Lou,
use config.pro option file_open_default_folder working_directory. It works in WF5 and also in Creo Parametric.
Martin Hanak
Martin Hanák
Hi
When you are setting start in directory to specific folder; please place your config files(Config.pro,config.win etc) in that folder.
After this you will not face this problem.
Try this and reply
K.Mahanta
Lou,
Martin Hanak
Martin Hanák
That was the option I was looking for. Thanks for the help!
Martin,
Can you please elaborate a little bit as i select the the option working_directory in Creo Parametric 2.0 and also saved that to the config.pro but it next startup it again set to my documents.
Naeem,
open config.pro in Notepad editor and add new line at the end of this file - see below. Then restart CR2.
Martin Hanak
Martin Hanák
