I am new to PTC Creo. After I finish the installation and open up Creo, I realized the model tree's font is too big and is hard to find the right part while the fonts are so big. Does anyone know how to fix this problem? I have attached 2 screenshots to show the problem.
There are a few configuration options you can set: defualt_font, font Size_size, and model_tree_font. You can also drag the model tree border to resize it left to right or separate the model tree so it is a separate window.
Got it, changed default_font to arial, 9 and it works fine. Thanks!
