Prior to CREO 6, I can install a new release of CREO on my machine and create a 7zip archive. Users can extract this archive and install this on their machine without using the software center or requiring local admin rights. With the new releases now, you have to run the creoagent (creosvcs_64.exe) which requires admin rights. PTC support stated that this is not a supported method, and not offering any workarounds. I believe some folks are still using this method for their deployment. Just curious how I can do this for our CREO 10 deployment and not have to rely on the software center.
Thank you all in advance!
Calvin
try simple test:
Note: In Creo 9.0 I had to add following lines at the end of parametric.psf file. Path corresponds with my installation.
ENV=CREO_AGENT_EXE_PATH=E:\PTC\Creo9_020\Creo\Agent\creoagent.exe
ENV=CREO_AGENT_LDP_LIST=E:\PTC\Creo9_020\Creo\Platform\9\manifests
try simple test:
... and read https://community.ptc.com/t5/System-Administration/Unattended-install-of-ptc-creo-7-with-licensing-server-using/td-p/701348 discussion.
Thanks, I will try this and update this post 🙂
