GETTING ERROR WHILE RUNNING MAPKEY IN VB-API
avijayan-2
Hello Everyone.
I have created a MAPKEY to choose a config file from the Working Directory. Its working fine in manual mode.
Now i have added this mapkey to a Button Function. What actually the button will do is it will launch the CREO first after that it should run the mapkey to select the config file.
Launching CREO is working fine but its not running the macro.
Should i declare anything before i call the function " IpfcBaseSession.RunMacro" when i went through the VB-API document i didnt find any such thing.
Below is my CODE and ERROR Message.
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
  Dim asyncConnection As IpfcAsyncConnection = Nothing
        Dim form As Form2
        Try
            lblStatus.Text = ""
            If TextBox1.Text = "" Then
                MsgBox("Please enter  Creo Parametric path", MsgBoxStyle.Critical)
                lblStatus.Text = "Please enter  Creo Parametric path"
            Else
                lblStatus.Text = "Starting  Creo Parametric Session ..."
                Me.lblStatus.Refresh()
                Me.Cursor = Cursors.WaitCursor
                asyncConnection = (New CCpfcAsyncConnection).Start(TextBox1.Text, ".")
                If Not (TextBox2.Text = "") Then
                    asyncConnection.Session.ChangeDirectory(TextBox2.Text)
                End If
                Me.WindowState = FormWindowState.Minimized
                form = New Form2(asyncConnection)
                form.ShowDialog()
            End If
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
            If Not asyncConnection Is Nothing AndAlso asyncConnection.IsRunning Then
                asyncConnection.End()
            End If
            lblStatus.Text = "Error occurred while starting new Creo Parametric Session"
        Finally
            Me.WindowState = FormWindowState.Normal
            Me.Cursor = Cursors.Default
            Me.Refresh()
        End Try
        IpfcBaseSession.RunMacro( c @MAPKEY_LABELCONFIG;~ Select `main_dlg_cur` `appl_casc`;\,
                                    Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdRibbonOptionsDlg` ;\,
                                    mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\,
                                    mapkey(continued) ~ Select `ribbon_options_dialog` `ConfigLayout.ImportExportBtn`;\,
                                    mapkey(continued) ~ Close `ribbon_options_dialog` `ConfigLayout.ImportExportBtn`;\,
                                    mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.Open`;\,
                                    mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\,
                                    mapkey(continued) @MANUAL_PAUSESelect Config File..........;\,
                                    mapkey(continued) ~ Command `ProFileSelPushOpen_Standard@context_dlg_open_cmd` ;\,
                                    mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;)
    End Sub
For error message please see the attached image.
Kindly help me to solve this issue.
With Regards
Aghil.M
I'm only familiar with J-Link, but the API looks similar. Maybe it even follows the same rules. Try the following for the RunMacro(..) method:
IpfcBaseSession.RunMacro("Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdRibbonOptionsDlg` ;
                                    ~ Activate `ribbon_options_dialog` `OkPshBtn`;")
Be aware that i have no idea how to concatenate a string in VB and also I'd think you cannot put a @MANUAL_PAUSE line into the macro. I'd replace it with regular UIShowMessageDialog(...) instead if there is such a thing in VB API, and split the whole thing into two RunMacro(...) methods.
~J
~J
avijayan-2
(To:James62)
Hi james,
Thanks for the reply. it solved my problem.
Arthur
(To:avijayan-2)
hi Aghil.M,
can you post your code for using mapkeys? I can't make it work.
Thx in advance
