Is there a config setting to make placement constraint Coincident the default?
Doug_Fowler
Is there a config setting to make Placement constraint Coincident the default as Normal or distance seems to be the current defaults? Taking time to drag a part and orient it prior to placement in a large assembly is not efficient. Most of my assembly constraints tend to be Coincident and rarely (never) Normal.
TomU
(To:Doug_Fowler)
comp_angle_offset_eps 91
comp_normal_offset_eps -1
auto_constr_always_use_offset never
See: Re: Assembly constraints
I found the answer by trying to submit a case for this question, which in retrospect should have been my first step. Turns out a similar case was previously submitted; CS198652. Set the config.pro options:
  • comp_angle_offset_eps to 91
  • comp_normal_offset_eps to -1
  • auto_constr_always_use_offset to never
It had been years since I last submitted a case and so I was pleasantly surprised to see the case submittal process has sufficient Artificial Intelligence (AI) search algorithms to bring up possible answers before a new case has to be submitted.
BTW,
Thanks, Tom.
Hello Douglas,
thank you for your feedback!
At PTC Technical Support we have in fact invested some efforts (and money!) during the recent years to enable better self-help.
Comments like yours make us proud and confirm we are going the right direction.
But our recommended "order" of steps would be:
This usually increases the chance to get the answer as fast as possible.
(and of course for questions regarding how to use the functionality, the PTC/Help should come first or maybe at least second)
Gunter
