Hi Everyone
I am using two separate detail files for two different config options:
drawing_setup_file
format_setup_fileWhen I create a new drawing, I get the following error in the Message Log:
Error(s) in C:\Program Files\PTC\Creo 11.0\custom\ISO-prt-asm.dtl. See datafile.ers.
In datafile_error.txt, the error is:
ERROR - C:\Program Files\PTC\Creo 11.0\custom\ISO-prt-asm.dtl, line 2: Invalid value 'CALCULATED' for keyword 'text_height'.Note:
Both detail files contain the same config option text_height.
In ISO-prt-asm.dtl (used as drawing_setup_file), the entry is:
text_height CALCULATED (Causing an error)
In ISO-frm-prt-asm.dtl (used as format_setup_file), the entry is:
text_height 3.5 (Not causing an error)
OBSERVATION:
If I changed the value of "text_height" from 3.5 to "CALCULATED", ISO-frm-prt-asm.dtl file is also making an same error I mentioned above.
Software: Creo Parametric 11
Can Someone help me on this?
Thanks.
Hi @KS_13238586
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
text_height calculated works only for model dtl-file
used for MBD for example
for formats/drawings dtl text_height calculated is incorrect
