No valid license for Creo Elements/Direct Modeling Express 4.0
ptc-4309170
1-Visitor
I have installed Creo Elements/Direct Modeling Express 4.0, but cannot gat past the splash screen. I am connected to the internet, I have NET framework 2.0 SP2 and the firewall is turned off - any ideas how I can get the program running? It has never worked
fhuslik
7-Bedrock
(To:fhuslik)
Answer to my own post:
The write access to the registry key:
HKEY_CURRENT_USER\Software\CoCreate\OneSpaceModelingPE
failed.
Just set the permissions in regedit to allow it to you and the system to write the key.
Then restart Creo.
If it helps, I also get the following error message every time I try to run the program:
OLAPEPP has encountered a problem and needs to close. We are sorry for the inconvenience
You forgot to mention what Windows OS are using.
Sorry -
Windows XP Home SP3
Dual Core 1.73GHz
2Gb RAM
Exactly he same here..
Config:
AMD Dual Core Athlon 5000+, 2,6GHz
4 Gig RAM,
XP home SP3
No other Problems with machine.
It also never worked.
fhuslik
7-Bedrock
(To:fhuslik)
failed.
Then restart Creo.
