ho insatallato onespace pe2 sul portatile quando vado a salvare un lavoro, il programma mi si chiude e perdo tutto. in un primo momento qst problema non si verificava. sul fisso di casa non ho problemi. ho provato a installare e reinstallare il programma diverse volte. Qualcuno puo aiutarmi? il computer è nuovo con Windows vista. GRAZIE I've installed onespace modelling pe2 on a notebook but when i try to save the program close itself and i lose all the job. On home desktop i don't have any problem. i've tried to disinstall and reinstall but i've the same problem. the computer is with Windows vista. thanks
When exactly does the application terminate itself? When you click on File/Save, or after closing the file dialog? Did you install any shell extensions which integrate into the file dialog and/or Windows Explorer, such as zipper utilities, version control tools, converters... Claus
It terminate itself when i try to save. I've tried also with Ctrl+s. I think is something within the option of Windows vista i've changed, or some program i've installed. But i can't immagine what can be. I'm thinking of reinstal the system, because I'realy need to get trained with it. PS: I use Mcafee security center but i was using it while the program was working.
anonymous wrote:
vik - 2009-04-02 11:09 PM It terminate itself when i try to save.
