I've been playing in my config.pro for a bit and I can't figure out what setting I need to change to get an edit sketch to change to No Hidden for my Display Style instead of the gray mesh it changes to now. Please see pictures for a more accurate description of what I'm looking for! Any and all help is appreciated. Thanks for your time.
Steve
I guess you have to change display mode manually using UI button or custom mapkey.
I was thinking about a mapkey for it as well. Just wanted to see if there was any other way before I took that route. Thanks for your reply!
That image looks like you are editing a sketch of a part within assembly mode. You are activating that part when you edit the sketch (feature).
There is a option, DIM_INACTIVE_COMPONENTS (shaded_only, always, never) BUT if you are in shade mode, it won't switch your display to no hidden.
Yes it is an edit sketch in an assembly. Thank you for clarifying that, I apologize I left that out. I'll play with that option and see if it's something that makes this a little easier. Thanks for your help.
