how to compare two Integrity configurations
thussong
3-Newcomer
Does anyone have a slick way to compare two Integrity Workflow and Documents configurations (especially Fields and Types)?
Hi Todd,
Option 1: you can do the following:
1. run "im fields" and "im types" to get a list of fields and types
2. run now for each return "im viewfield XYZ >> fields_env1.txt" and "im viewtype XYZ >> types_env1.txt"
3. do this on the second environments to get fields_env2.txt and types_env2.txt
4. use a diff tool to compare both outputs
Option 2:
to compare individual types you may also compare the IntegrityDocs html output.
Option 3:
you could also generate the word export from the link below (solution #4) and compare them.
in terms of completeness the Option 1 is the best, any report from option 2 or 3 might be a bit incomplete
You can also check this:
Integrity LM: Administration Configuration Reports
Volker
kjain-2
(To:thussong)
Hi Todd,
As Volker replied to you in such a nice way i also suggest to you go with Option 1 that is much simpler and effective too. As i unaware about your requirement too like in which aspects you want comparing ?
Kapil
