Home Mashup property - no redirection
gpaillot
I create an user and define a home mashup.
When the user log in, he's not redirect to the mashup. It is the Composer which is displayed.
How can the user be redirected to the home mashup defined ?
Maybe I use the wrong URL ?
I use https://myIPserver/Thingworx
Hi Gaelle,
This should work if you have setup the home mashup in the user profile. It also works on organization level, on user group level this is not working.
You can check out other ways of doing redirection on our knowledge database:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS181528&ptcsource=ptcu
If that does not help, maybe useful to log a support ticket.
Thomas
Hi Gaelle,
Thomas
Hi Thomas,
Thanks for your link, very useful.
It's ok
paic
(To:gpaillot)
Make sure to remove your user from the Administrators group.
