Message ::TypeError: Cannot call method "GetJSON" of null
IA_10816220
I have a Scheduler that execute this code :
// Define the Thing that contains the service
me.flag1 = 1;
// Call the service (e.g., GetAPIData) of the API Thing
Things["Eastern.SecurityVehiclesAPI.parser"].GetAPIData();
logger.warn("Tracking.API.Scheduler_3 subscriptionToCallTheService executed");
me.flag1 = 2;
and here is the service code itself
//code
// API endpoint and headers
var apiUrl = "http://212.70.49.13/ewe.agent/api/v1/online-history/fleet/2100/all-vehicles";
var headers = {
    "Accept": "*/*",
    "Accept-Encoding": "gzip, deflate, br",
    "ApiKey": "xxxxx" // Replace with your actual API key
logger.warn("getapidata 2");
//var result = contentLoader.GetJSON(params);
// Make the HTTP GET request
    var result = Resources["ContentLoaderFunctions"].GetJSON({
        url: apiUrl,
        headers: headers,
        timeout: 10000 // Timeout in milliseconds
logger.warn("getapidata 3");
    // Store the response in a property or return it
	me.APIResult = result;
	//logger.warn("API Response: " + JSON.stringify(result));
the service itself when i run it it works fine without any errors , but when the Scheduler runs it i get this error:
Error in: Eastern.SecurityVehiclesAPI.parser.GetAPIData javascript service. Message ::TypeError: Cannot call method "GetJSON" of null (GetAPIData#15)
please note that this service and scheduler used to work on another platform and was fine so i am sure that the codes are correct, also both platforms run the same thingworx version
so what might be wrong or even how to debug more for this one ?
thanks
Rocko
(To:IA_10816220)
The user executing the subscription may not have the necessary privileges (Visibility) on the Resources entity so it can't access the ContentLoaderFunctions. So check the user you entered in the scheduler.
Rocko
(To:IA_10816220)
