Passing values between tabs
Vipul_Oswal
I need to pass values from one tab to another,I have 3 tab each having one mashup. I want to pass selected value from the first tab's mashup to other 2
Velkumar
(To:Vipul_Oswal)
Hi @Vipul_Oswal
You have to create a Mashup Parameter in all 4 Mashups. And pass the selected value from Tab 1 to its Mashup Parameter
Bindings in Mashup 1
In the main Mashup, pass the value from Tab1 to the main Mashup Parameter
From the main mashup, pass the value to the remaining tabs contained mashup
The result should look like this
Please find attached entities for your reference.
/VR
Velkumar
(To:Vipul_Oswal)
Hi @Vipul_Oswal
You can use Mashup Parameter or Session Value to achieve this.
I would prefer to use Mashup Parameter - Configuring Mashup Parameters (ptc.com)
Thingworx Session parameters - Session Parameters (ptc.com)
/VR
Vipul_Oswal
(To:Velkumar)
Regarding your ans. I am unable to add the mashup parameters. I have set up like below,
1) I have a Main mashup containing 3 tabs which redirects to 3 mashups.
2) On 1st mashup, I have Machine list, on selection display all selected machine details.
3) 2 and 3 mashup have related mashup to the first one.
I wanted to pass the machine name selected from 1 mashup to 2 and 3. I was unable to achieve this with the mashup parameter, Can you please suggest?
Velkumar
(To:Vipul_Oswal)
Hi @Vipul_Oswal
/VR
