Referencing Widgets in Services
tscur
Hi all,
I've been developing in Thingworx for a while now and I was wondering if it was possible to reference a Widget Property in a service, something like:
if (condition) {
     [WidgetProperty] = [Something];
} else {
     [WidgetProperty] = [SomethingElse];
I know that Widgets have pre-defined services and inputs/outputs but my question is: Could I write a code that defines the input of the property based on a condition? If possible, how do I reference this property in the service?
Thank you.
mnarang
17-Peridot
(To:tscur)
You can not access widget reference in Thingworx JS service .This is doable in Studio (which is another AR product ) using angular snippet . But as per Thingworx it is not feasible .But you can use expression/Validator widget to evaluate a JS expression(condition) and use the output to bind to widget services .
Thanks ,
Mukul Narang
mnarang
17-Peridot
(To:tscur)
Thanks ,
Mukul Narang
tscur
(To:mnarang)
Thank you for your answer @mnarang !
I've never used the Expression/Validador Widget, could you help me understand how it works?
Taciano
mnarang
17-Peridot
(To:tscur)
For expression widget - https://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=ExpressionWidget&action=show
There is also a video link for how to use expression widget in above link .
For Validator widget - https://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=ValidatorWidget&action=show
One more: - https://www.ptc.com/en/support/article/CS250781
Let me know if you face any problem after seeing these links .
Thanks ,
Mukul Narang
tscur
(To:mnarang)
Thank you for your help @mnarang ! Will do.
tscur
(To:tscur)
Ok @mnarang , I saw the articles and videos and I am trying to see how it would work for me.
Let me explain the situation:
For example, I have a Data Table called People with two fields (Name [String], Numbers [InfoTable]). The Infotable Numbers has two fields (Number [Integer], Name [String]). My problem is that I have a Widget in which I am showing the data of a People's selected row's Numbers, keep this in mind. However, when the user clicks  "Add Person" in the People Data Table, i want to create a Data Table entry but also show the Numbers Infotable being created adding some rows to the Infotable. How can I use the same Widget to show both of the data.
Basically, I want to activate an Adding Mode, not having to create another mashup and using the same widget.
Taciano
