ThingWorx User authentication case sensitivity issue using Windchill Authentication
vijayaRath
We are using Windchill Authentication for ThingWorx user authentication.  Windchill can authenticate the AD users and doesn't validate case sensitivity, ThingWorx authentication fails for user when UserName is Upper/Lower Case . Example: if AD username is  xyz.pqr, User can login and authenticate to Windchill with any username ( Xyz.Pqr/ xyz.pqr). However, in ThingWorx user can't get Authenticated with Xyz.Pqr
We've implemented SSO using Windchill 12.0.2 with TWX -9.3.
I know other enterprises using ThingWorx extensively with 1000s of  concurrent users logging into system. Anyone can help?  How to handle User Management in ThingWorx and Navigate?
abandal
(To:vijayaRath)
Hello @vijayaRath,
The use case (enhancement request: "login username case-insensitive") mentioned in this post is currently not a part of the ThingWorx functionality. Also, this enhancement request is already in our (PTC) backlog.
This enhancement request could be considered in future releases of ThingWorx/Navigate; however, no timeline can be committed to at this time.
Abhi
Rocko
(To:vijayaRath)
Looks like your users will have to use the proper case.
For reference:
https://www.ptc.com/en/support/article/CS244222
https://www.ptc.com/en/support/article/CS259466
vijayaRath
(To:Rocko)
Articles Suggest to Use PingFed with PTC Cloud . Are there any other Alternate approach ? We are not using PTC Cloud.
Rocko
(To:vijayaRath)
That's why I said they have to use proper casing, I don't see another solution. The solution with PingFed is not tied to PTC Cloud, but I don't know details. Maybe create a ticket with support for that.
abandal
(To:vijayaRath)
Hello @vijayaRath,
Abhi
vijayaRath
(To:abandal)
Thank You Abhi for Notifying. We will  require an workarouns untill we move to Fixed Build . Any ODea how Other CUstomer's are resolving this issue
abandal
(To:vijayaRath)
Hello @vijayaRath,
I have discussed this issue with our team, and unfortunately, currently we don't have a proper workaround for this issue.
For now, please try to use the exact username while logging into ThingWorx.
Abhi
