"Test" button in service is not visible.
egolindano
7-Bedrock
Hi. I'm currently trying to create a service using the java API, it creates fine, but when i go to the Composer and try to execute it the "Test" button is not visible.. Any idea about the cause of this? Thanks in advance.
Java code
vxavier
(To:egolindano)
Are you trying to run this service in a thing that have your thing template?
Just things can run services. To test you have to create a thing with this thing template. Did you do that?
vxavier
(To:egolindano)
Hi, VXavier, thank you for answering.. It was a silly mistake from me.. Indeed, i wasn't trying to run the service from a Thing
vxavier
(To:egolindano)
If this was the solution for you, please mark as Accepted to help the community.
Best practice for users who post: Accept as Solution
