Hi everyone,
I’m working with the Grid Layout in Vuforia Studio and I’m trying to dynamically show or hide specific rows.
The problem I’m facing:
I cannot dynamically change the row or column class.
I also cannot set their height/size to 0px at runtime.
Simply hiding the widget inside the cell doesn’t help, because the row and column space remains visible.
My goal is simple:
I want all rows to exist in the layout, but I want to toggle their visibility (visible/invisible) without leaving empty space.
Is there any workaround or method to:
hide a full row in a Grid Layout?
collapse its height (similar to CSS display: none)?
or dynamically modify grid definitions at runtime?
Any suggestions or best practices would be greatly appreciated.
Thank you!
After some testing i am able to find my own solution for this issue.
class (application)
.hideRowDynamic div.row[data-hide="true"] {
display: none !important;
Assign this class to gridLayout on which you would like to have this behaviour -> hideRowDynamic
home.js
$scope.hideRow = function (rowIndex) {
let widget = document.querySelector('[widget-id="gridLayout-77"]');
if (!widget) return;
let rows = widget.querySelectorAll("div.row");
if (rows[rowIndex - 1]) {
rows[rowIndex - 1].setAttribute("data-hide", "true");
call the function on button click or in angular.element(document).ready(function () { })
$scope.hideRow("7");
It would for example hide the 7th row from grid layout..
class (application)
home.js
