Sequence not working on hololens 2
vivekse
I tried to run some basic sequences run on hololens 2 but nothing happened. There was no sequence running in it. I am also attaching my project just to show what i did.
Any help would be appreciated.
tmccombie
(To:vivekse)
I reproduced this locally using your project. seems to work in preview but not on the HL. What version of Creo Illustrate did you use to create the sequence?
vivekse
(To:tmccombie)
I have been using creo illustrate 6.0
