Creating custom preference with loadfile
rhart
16-Pearl
Version: Windchill 12.1
Use Case: Need to create a preference which only accepts a number as input
Description:
I can create string, type or boolean preferences using a loadfile with the right handler, but I cant find any example handler for Integer, does it exist?
e.g. Boolean
com.ptc.windchill.enterprise.preference.handler.BooleanPreferenceValueHandler:
e.g. String
com.ptc.windchill.enterprise.preference.handler.StringPreferenceValueHandler:400:400
e.g. Type Picker
com.ptc.windchill.enterprise.search.preference.handler.TypePreferenceValueHandler:/com/ptc/windchill/enterprise/search/allSearchTypes
e.g. Integer
??? where do you find it?
e.g. Preference loadfile
<?xml version="1.0"?>
<!DOCTYPE NmLoader SYSTEM "standardX10.dtd">
<NmLoader>
	<!-- Clean up first-->
	<csvUnlinkPreferenceClientDefinition
		handler="wt.preference.LoadPreference.deleteClientDefinitionLink">
		<csvname>/ext/ws/elecReportDocumentType</csvname>
		<csvclientName>WINDCHILL</csvclientName>
	</csvUnlinkPreferenceClientDefinition>
	<csvDeletePreferenceDefinition
		handler="wt.preference.LoadPreference.deletePreferenceDefinition">
	</csvDeletePreferenceDefinition>
    <csvPreferenceDefinition handler = "wt.preference.LoadPreference.createPreferenceDefinition">
		<csvvisibility>ORGANIZATION</csvvisibility>
		<csvcategoryName>COMPANYE_WS</csvcategoryName>
		<csvdisplayName>ext.core.prefs.PreferenceRB:COMPAN_WS_ELEC_REPORT_DOC_TYPE</csvdisplayName>
		<csvdescription>ext.core.prefs.PreferenceRB:COMPANY_WS_ELEC_REPORT_DOC_TYPE_SHORT_DESC</csvdescription>
		<csvlongDescription>ext.core.prefs.PreferenceRB:COMPANY_WS_ELEC_REPORT_DOC_TYPE_LONG_DESC</csvlongDescription>
		<csvdefaultValue>WCTYPE|wt.doc.WTDocument</csvdefaultValue>
		<csvhandler>com.ptc.windchill.enterprise.search.preference.handler.TypePreferenceValueHandler:/com/ptc/windchill/enterprise/search/allSearchTypes</csvhandler>
	</csvPreferenceDefinition>
	<csvLinkPreferenceClientDefinition handler = "wt.preference.LoadPreference.setClientDefinitionLink">
	</csvLinkPreferenceClientDefinition>
</NmLoader>
HelesicPetr
(To:rhart)
Hi @rhart
If you try to search a csvPref definition in all files in the Windchill folder, you could find what you are looking for.
example with number
  <csvPreferenceDefinition handler="wt.preference.LoadPreference.createPreferenceDefinition">
       <csvname>/Tables/DataSourceClientSideLimit</csvname>
       <csvvisibility>USER</csvvisibility>
       <csvcategoryName>TABLES_CATEGORY</csvcategoryName>
       <csvdisplayName>com.ptc.core.components.rendering.renderResource:CLIENT_SIDE_DATASOURCE_MAX_LIMIT_NAME</csvdisplayName>
       <csvdescription>com.ptc.core.components.rendering.renderResource:CLIENT_SIDE_DATASOURCE_MAX_LIMIT_DESC</csvdescription>
       <csvlongDescription>com.ptc.core.components.rendering.renderResource:CLIENT_SIDE_DATASOURCE_MAX_LIMIT_LONG_DESC</csvlongDescription>
       <csvdefaultValue>2000</csvdefaultValue>
       <csvhandler>com.ptc.windchill.enterprise.preference.handler.NumberPreferenceValueHandler:1:100000</csvhandler>
PetrH
HelesicPetr
(To:rhart)
Hi @rhart
example with number
PetrH
Thanks @HelesicPetr  I found it in there, it's called com.ptc.windchill.enterprise.preference.handler.NumberPreferenceValueHandler:1
I was searching Integer
HelesicPetr
(To:rhart)
Hi @rhart
I used "csvPreferenceDefinition" as a search key word ::D
PetrH
