Hide an attribute on layout customization?
abennis
Hello everyone,
I have to hide an attribute on a layout when another attribute change the value.
for exemple :
Attribute A : boolean
Attribue B : String
If attribute A is false, Attribute B is hidden on the layout.
A.B
pwolski
(To:abennis)
I think you can't hide attribute, but you can make Attribute 2 not editable thanks Data Utility.
abennis
(To:pwolski)
Thanks for you reply
I found out a method preValidateAttribute in DefaultUIComponentValidator, i found no documentation about that. But i will try to use this validator on my attribute.
Hi Anas Bennis‌,
It is ok if we make second attribute non-editable on editable and it depends on first attribute value we select?
For example:
I remember I had done something like this in recent past. If that is ok for you I can again give it a try and share my findings.
Shirish
Hi @ShirishMorkhade,
Can you explain me how you did that?
It'll help me a lot.
Hi @Mehmet_Ozdemir
I believe that there are many ways how to do so.
One is to use js scripts to change the attribute input field properties as a hidden, disabled and so on.
All you can done in JSP pages of your wizard.
example of the checkbox
it reacts on a mouse click
<wrap:checkBox name="CADDocument" id="CADDocument" label="CAD Document" renderLabel="true"
renderExtra="enabled"
renderLabelOnRight="true" checked="true" onclick="defineCADType('CADDocument')"/>
example of the script
<script type="text/javascript">
    function defineCADType(buttonPushed) {
        var checked =document.getElementById('CADDocument').checked;
    if (checked !== true)
      document.getElementById('prt').hidden = true;
      document.getElementById('asm').hidden = true;
      document.getElementById('drw').hidden = true;
        }else{
          document.getElementById('prt').hidden = false;
          document.getElementById('asm').hidden = false;
          document.getElementById('drw').hidden = false;
</script>
in your case you can set onChange event on a textbox
PetrH
