I am working on our company's CI/CD and I want to add logic to perform certain functions when certain files/paths are changed since the last pipeline run.
One of these action is the restartAllLocalMethodServers command found in JConsole. I'm familiar with running it from JConsole, but can't seem to find a class path to try calling it from command line.
If there is no main function for whatever class this is built into, it'd be worth writing my own java utility class to call it.
How can I perform a restartAllLocalMethodServers through Command Line?
I figured it out!!!
So when you run
```ps1
function Invoke-SlowlyKillMethodServers {
.SYNOPSIS
Stops Windchill Method Servers one at a time.
.DESCRIPTION
Collects a list of currently running java.exe processes using the MethodServerMain class. It stops each process, waiting the string regex 'ready.*in.*secs' to appear in new method server logs.
.INPUTS
None. You cannot pipe into this function.
.OUTPUTS
None. There are no outputs from this function.
.EXAMPLE
PS E:\ptc\Windchill> Invoke-SlowlyKillMethodServers
944 Logs: 2020-10-07 15:13:07,284 INFO [main] wt.method.server.startup - MethodServer ready (in 71.048 secs).
12220 Logs: 2020-10-07 15:14:24,352 INFO [main] wt.method.server.startup - MethodServer ready (in 68.979 secs).
8516 Logs: 2020-10-07 15:15:24,232 INFO [main] wt.method.server.startup - BackgroundMethodServer ready (in 52.078 secs).
6800 Logs: 2020-10-07 15:16:26,187 INFO [main] wt.method.server.startup - BackgroundWVS ready (in 54.043 secs).
[CmdletBinding()]
param (
[Parameter()]
[int32]
# Number of seconds to wait between stopping processes.
$Seconds_To_Wait = 120
$MethodServers = Get-WmiObject Win32_Process -Filter "name = 'java.exe'" | Where-Object CommandLine -Match "MethodServerMain"
$InitialMethodServers = $MethodServers | Select-Object -Property ProcessID | ConvertTo-Json -Compress
foreach ($MethodServer in $MethodServers) {
Stop-Process -Id $MethodServer.ProcessID -Force
While (Get-Process -Id $MethodServer.ProcessID 2>$null) {
Start-Sleep 1
$EndTime = [datetime]::UtcNow.AddSeconds($Seconds_To_Wait)
do {
do {
$ActiveMethodServers = @()
$ActiveMethodServers += Get-WmiObject Win32_Process -Filter "name = 'java.exe'" | Where-Object CommandLine -Match "MethodServerMain"
} while ($MethodServers.Count -ne $ActiveMethodServers.Count)
$LatestMethodServerID = $ActiveMethodServers.Where({$true}, 'Last', 1).ProcessID
$LatestMethodServerLogsTail = Get-ChildItem "$env:WT_HOME\logs" -filter "*$LatestMethodServerID*log4j.log" | Get-Content -Tail 1
$LatestMethodServerReadyString = Get-ChildItem "$env:WT_HOME\logs" -filter "*$LatestMethodServerID*log4j.log" | Get-Content | Select-String "ready.*in.*secs"
$LatestMethodServerReady = [bool]$LatestMethodServerReadyString
$TimeRemaining = $EndTime - [datetime]::UtcNow
Write-Progress `
-Activity "Killing $($MethodServer.ProcessID)..." `
-Status "Initial Method Servers: $InitialMethodServers" `
-CurrentOperation "$LatestMethodServerID Logs: $LatestMethodServerLogsTail" `
-SecondsRemaining $TimeRemaining.TotalSeconds
} while (-not ($LatestMethodServerReady))
Write-Output "$LatestMethodServerID Logs: $LatestMethodServerReadyString"
Sorry there's no powershell syntax highlighting in this forum 😞 used C# syntax highlighting instead.Hi,
I am not sure if you are aware but you can run "windchill stop" and "windchill start" from a windchill shell.
I have seen this launched from an ant script session an works pretty well.
However, if you are running Windchill as Service you may want to read this article:
https://www.ptc.com/en/support/article/CS116636
This is true also if your windows service is using a service account to launch it.
I hope this helps.
Unfortunately that would stop all of Windchill causing system downtime for the users.
Not all of our changes will require this. Most of them just require the method servers to be restarted. The mbeans restartAllLocalMethodServers does this one at a time. It'll kill a method server (allow users of that method server to be picked up by another method server causing minimal downtime) then start a new method server, it won't continue until the new method server is responding, then move on to the next one.
The result of this is a "sluggish" period rather than a down time period. Almost more like a brown out than a black out for the windchill service.
I did not know about the behavior of restartAllLocalMethodServers, that's really cool!
I am not sure if this can help you, but looks like there is a RemoteMethodServers API.
RemoteMethodServer rms = RemoteMethodServer.getDefault();
rms.stopAllServers();
Could you please share the code on how were you able to use the restartAllLocalMethodServers API?
Hi
I 'm not sure this will help but what I understood is you need to restart only your Method servers. If you are not running a clustered environnement this can be achieved by a kill -9 of all your Method servers, the the ServerManager will restart new ones. To be able to kill all Your Method server on linux you can create a specific alias for windchill (ie wcms) command and configure your windchill starting property to use that command instead of windchill, then you will be able to kill all MethodServer process by filtering based on the specific command name:
ps ax | grep <snippet> | grep -v grep | awk '{print $1}' | xargs kill
If you have background method servers or Queues MethodServer make sûre to adapt this method
Hope this helps.
That's not a bad idea. Although i fear this wouldn't be very graceful. I'm in a windows environment so greping around for me, unfortunately.
Here's what I came up with. Was thinking about trying to figure out when a new method got spun up and when it was "ready" but that was getting stupid fast. Starting with this for now.
[CmdletBinding()]
param (
[Parameter()]
[int32]
$Seconds_To_Wait = 60
While (Get-Process -Id $MethodServer.ProcessID) {
Start-Sleep 1
Start-Sleep $Seconds_To_Wait
I still have not figured out how to do this... i'm thinking it'll require the use of a jmxclient jar. Haven't made it any further on this though. Am thinking about writing a utility class if i'm able to import the class.
I figured it out!!!
So when you run
```ps1
.SYNOPSIS
.DESCRIPTION
.INPUTS
.OUTPUTS
.EXAMPLE
[CmdletBinding()]
param (
[Parameter()]
[int32]
Start-Sleep 1
do {
do {
Write-Progress `
