Version: Windchill 13.0
Hi everyone, I found a reference in the ptc support explaining that it’s possible to retrieve Primary End Items in Windchill using REST API by filtering on WCTYPE|wt.pdmlink.PDMLinkProduct as typeId and selecting productReference. However, I’m not sure what the exact endpoint is to call in order to retrieve this data.
Link: https://www.ptc.com/en/support/article/CS271349
Could someone please share a concrete example of the full REST endpoint (including base path and entity name), ideally with $select or $expand usage if applicable? Thanks in advance for your help!
Description:
Retrieve Primary End Item via REST API
Just to clarify - I'm specifically looking to retrieve this data using the OData API, not WRS or classic REST. Appreciate any examples or guidance.
Thank you for your question.
Also, feel free to add any additional information you think might be relevant.
