Unable to update WTVariance
adev-2
I am trying to update the WTVariance object IBA but can't see the updated values can any one help me how I can do this using code
I am using this code right now
try{
            wt.change2.WTVariance var = (wt.change2.WTVariance)primaryBusinessObject;
            com.ptc.core.lwc.server.LWCNormalizedObject obj = new com.ptc.core.lwc.server.LWCNormalizedObject(var , null,java.util.Locale.US, null);
            obj.load(att);
            obj.set(att,attValue);
            obj.apply();
            //PersistenceHelper.manager.refresh(var );
            catch (wt.util.WTException e) {
                            e.printStackTrace();
HI @A D,
Please refer below code snippet for your reference.
Note: This example code is just for your reference. Kindly verify it on test server first.
public class UpdateWTVariance implements RemoteAccess {
  * @param args
  * @throws InvocationTargetException
  * @throws RemoteException
  public static void main(String[] args) throws RemoteException, InvocationTargetException {
  RemoteMethodServer rms = RemoteMethodServer.getDefault();
  rms.setUserName("wcadmin");
  rms.setPassword("ts");
  rms.invoke("updateVarianceIBA", ext.UpdateWTVariance.class.getName(), null, null, null);
  public static void updateVarianceIBA() throws WTException {
  ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.change2.WTVariance:2336782");
  WTVariance var = (WTVariance) PersistenceHelper.manager.refresh(oid);
  System.out.println("Variance Name: " + var.getName());
  PersistableAdapter theIBAs = new PersistableAdapter(var, null, java.util.Locale.US, new UpdateOperationIdentifier());
  theIBAs.load("savedAmount");
  theIBAs.set("savedAmount","14562");
  theIBAs.apply();
     // Persisting IBA Value
     PersistenceHelper.manager.modify(var);
     System.out.println(" *** Update Success *** ");
I hope this helps you.
Shirish
Hi Shirish,
Thank you so much for your help yes it worked for me
sorry for late reply
